Perforating leathers at home
11 posts Started 22 May 2006 Last recovered post 23 May 2006 Wayback Machine snapshot 24 Oct 2006
Well, I live where it gets HOT. I have a Vanson jacket that is fully perforated and mesh gear, but I wanted a two piece that I can use for track days. Could not afford new Vanson stuff so I bought an Alpinestars GPU on closeout from Motostrano. It has some perforatrion, but not near enough so I started in on it tonight. I got one panel done, tell me what you think.
Before:
[image: user posted image]
After:
How did you do it?
I'm guessing he fed some termites Essence of Pedant, mixed with a little blood from a VFR owner.
A 1/16 leather punch and about an hour smile.gif
Very cool. But, then I guess that's the whole point.
tbzep, May 22 2006, 10:57 PMHoly leather, Batman!  ohmy.gif
It's a good concept, just realize that those holes just took alot of integrity off the jacket. As to where it would slide and scuff before..Now it will slide and tear
That looks totally pro! So, is the jacket lined in the area where you've made the perfs? If so, did you also perforate the lining?
I've got some pants that could use perfs in non-stress areas -- they're bloody hot if the weather gets to 70 degrees or so.
enzed_viffer, May 23 2006, 03:38 AMI'm guessing he fed some termites Essence of Pedant, mixed with a little blood from a VFR owner.
Dayyum you were so close too goofy.gif Who the hell would have guessed a leather hole punch comp13.gif
Red98V4, May 23 2006, 01:01 PM
No doubt some loss of strength. I am not going to perforate the high spots, elbows, butt, knees, back; here is a picture of a fully perforated jacket after a slide. It is almost 100% perforated, even over the elbow that slide. I bought the jacket this way and while it is not cosmetically pretty, it did not tear and is fully functional.
While it has turned cooler where I live right now, last week it was already breaking into the 100's huh.gif
Zonker, those are the pants. I slid a piece of hard rubber between the leather and the lininig which is nylon mesh. I am not sure how I will do the jacket as there is no place to get behind the mesh lining.
I emailed a few leather shops, and they either wanted over $180.00 to perforate the leathers, or used 1/8th holes which I felt look too big.
End of thread · 11 posts recovered Wayback Machine snapshot 24 Oct 2006
