[image: View Post]Ryanme17, on Oct 3 2009, 12:49 PM, said:
[image: View Post]hoopdc, on Oct 2 2009, 06:23 PM, said:
I've heard heated grips are "OK". And having a nice big glove that goes way over up your wrist is important as it keeps any wind out. But...............bottom line...............there is no substitute whatsoever for a heated vest ( with sleeves ) and heated gloves that are plugged into the same heated vest.
Granted this set-up is way more expensive than any single pair of gloves but you'll feel comfy ( not just "OK" ) until the temps get way down. I've had Gerbing's heated clothing for almost 20 years now. Far and away the best, most important gear I've ever bought. With normal care ( no abuse ) the electric gear should last a lifetime.
All this with just one wire hanging from your normal clothes.
Right, the advantage to heated grips is that it is available on your bike all the time if you forget your gear, or if you're like me and don't always plan the best for rides. Grips are also significantly cheapter, at like $35. What does a jacket, gloves, and powerlet port/adapter costs, $300? Heated gear is definitely best, though.
+1
I have a lot of heated gear, including a Gerbing liner, but I run my heated grips a lot, even in the summer. If it's 70 degrees out but it starts misting rain, I'll turn the grips on low and they will keep my hands nice and comfortable, and dry my gloves as well. Or maybe it gets dark and the temps drop just a little bit. I would never pull over and load up on heated gear in these conditions, in fact I might be running the heated grips even though I've got all the vents open on my jacket. I never noticed, until I got heated grips, that unheated grips can be really freakin' cold, even when the air isn't.
I have owned two pairs of heated gloves. I hated them both, they were just too bulky. My hands are small and slender and I just couldn't fight all that bulk. If you have meatier paws than I do, they might work better. I've been considering getting a set of
Hippo Hands. I think they'd work very well with the grip heaters, while allowing me to wear comfortable gloves. Probably help with the death grip as well.
I have a friend who carries passengers a lot, either his wife or one of his kids. He says they complain of cold hands a lot and I've been trying to convince him to install grip heaters on the passenger grab rails. I think it would be cheap and elegant and nice for the passengers. Anyone ever tried this?
