How Did I Get Here?
OK, a while back I got a good deal on the OEM topcase rack and I've been searching high and low for a decent deal on a topcase to put on it. I figured if I was going to go, it was "go big, or go home" so that ruled out all of the sub-forty liter units. I would�ve stuck with Honda, but the OEM unit was just too expensive.
Why I Didn�t Go With Givi
I looked into the Givi cases. Challenge #1 was, "which one"? The only ones that I liked were the E450, E470, and V46.
The second problem was "how to mount it on the OEM rack"? For those of you uninitiated in the mysteries of the Givi product line, the �E� cases are Monolock cases, and the V46 is Monokey. The Monolock cases are ostensibly oriented towards scooters and light-duty uses. They have a smaller footprint and mounting plate. The Monolock cases are heavier and have a larger mounting plate. Givi�s cases don�t come with a mounting plate, though, so you either have to buy a �universal� plate or mount the box on one of Givi�s topcase racks. Obviously for me the former was the only option.
The concern that I had was would the universal plate fit, and if so how I would get it mounted? Universal plates are meant to be mounted to a rack by running machine screws/bolts through the �milk crate� bottom of the plate. I got a couple of people to do some measurements and found that the mounting bolt holes in the OEM rack were too widely spaced for the Monolock plate to fit. So, that meant Monokey only, which meant the V46. Problem was, $240 for the case, another $65 for the universal plate, plus shipping, and suddenly it�s not that much cheaper than the OEM unit. Grrrr.
Coocase (and Twisted Throttle) to the Rescue!
Then I discovered something called Coocase on Twisted Throttle�s site. Wow, look at this� the S48 Astra. Hmmmm. 48 liters, comes with a large universal mounting plate. Not bad. But wait, there�s more! LED brake lights, alarm(!), and (get this) a remote! Looks sharp, the price is reasonable ($275), and shipping is free until 10/15/08. The guy at Twisted Throttle says that their quality is really good, so I pull the plug. Always efficient, TT shipped it the same day.
Case showed up 4-5 days later as promised, and it�s really nice. Fit and finish look excellent, all of the bits (mounting plate, mounting hardware, wiring kit) are in the box. Grabbed the OEM rack and started looking at the alignment of the holes in the plate to see if it work work. Bingo, spot on! All I needed was four 6x1.0x50mm metric machine screws from the hardware store and everything bolted up just fine. I mounted the OEM rack on the bike and verified that I can remove the seat with the seat cowl and the rack/plate in place; good news there as I was worried about clearances.
The box requires that it be wired, unswitched, to the battery, and I didn�t time to figure out the cleanest way to do that so I just ran the wires under the seat and did a temporary hookup. Put the box on the rack, and 30 seconds later, it automatically locks! Cool. Pick up the remote, hit the button, �beep, beep�, it unlocks! Very cool!
Grabbed my son and had him verify that the LED brake lights work. Also tried out the alarm. It�s a motion sensor (with sensitivity adjustment in the box). Makes a reasonable amount of noise. Not a car alarm but it�s pretty loud and would certainly get your attention if you were anywhere near it.
The Bottom Line
I�ll post pics soon, but I wanted to get this information out there in case anybody looking for an early Christmas present and wanting to take advantage of the free shipping deal got the heads-up. This thing ROCKS! To summarize:
Pros
How Did I Get Here?
The Bottom Line
Pros
- Great quality � every bit as good as Givi (I have V35 bags)
- Big, but nice looking and not too bulky
- Stylish design goes well with the VFR
- Great features � alarm, LED brakelights, remote
- Mounting plate looks great when case is removed
- Comes with cover for electrical contacts on plate (used when box is off)
- At $275, the best value in a 40+ liter case, IMHO
- Has to be wired unswitched, so could drain battery if bike is left for long periods
- Alarm could be louder
- LED Brake lights aren't that bright
