Hi,
I own an 02 VFR and have been having problems with both a slow electrical drain that I can't find and a battery that didn't seem very strong. I got tired of charging it every week so I started looking for replacements.
The stock Honda battery is pretty expensive, and the auto parts store batteries have been tried before but are slight smaller and don't seem to have the same juice. After researching the topic, I decided to try out the Shorai Lithium Iron battery. I didn't find too many comments or reviews of the battery online but couldn't find anything negative either. The Lithium Iron batteries hold approx. 14% less capacity than the Lithium Polymers in your laptop. However, they don't suffer the fire hazards issues and have much longer recharge cycles. These are the types of batteries that are going into new power tools, the Chevy Volt, etc.
The Shorai website lists two batteries for all VFR 800 models, the LFX14A1-BS12 14 amp hour and the LFX18A1-BS12 18 amp hour. Compared to the stock replacement battery, lead-acid YTZ12S rated at 11 amp hour.
I decided to pull the trigger on the larger of the two. I settled on BatteryStuff.com after reading good reviews and couldn't be happier. They shipped it out quickly an emailed tracking numbers as well.
When I received the battey, the first thing you notice is how light it is. This think is a little over 2 lbs, more than 7 lbs lighter than stock! It is the same length but about half the width. Shorai includeds several foam inserts with double-sided tape that allows you to fill up the extra space. This is a drop-in replacement with no other changes necessary.
I installed the battery and cranked it up. The bike fired up quickly! The starter spun up noticeably faster than with even a new lead-acid battery. No more holding the start button for several rotations now. The bike even seems to idle more smoothly as well.
The main draw back to this battery is the price. I paid $180.00 for the battery, shipping was included. The smaller of the two sells for around $150. For people who are on a budget and are fine with there current battery, you may want to hold off. However, this battery is said to last 7-8 years in normal operation. Essentially double what the "average" motorcycle battery does. If you figure the YTZ-12S goes for around $75 and you would have to replace it twice during that 7-8 year period, you would be paying the same as the LFX14A1-BS12 14 amp hour in the end.
So, if you need to replace your battery soon, I would highly recommend the Shorai. Light weight, plenty of juice and (theoretically) twice the life. Now if I could just find that damn short.....
Todd
