#1 Thread starter
[image: gallery_491_1035_59675.jpg]
Farkles Farkles Farkles
I got a few motorcycle items for Christmas this year in the form of gift certificates, one was completely anonymous, I thought it was from my sister but she denies it? I don't know who the GC came from perhaps even from one of you members out there?? Whoever it was thanks it was enough to add to my gps fund to finally get one.
GPS
[image: user posted image]
Garmin Quest
I chose the Garmin Quest for its small thin size and ease of use, its a bit of a compromise, smaller screen, no expansion memory but its a darn nice unit, water proof and has Garmin quality.
I just ordered the motorcycle kit from Gps City
It came with an auto charger, home charger and a motorcycle charger with base and ram mount. I ended up using the ram arm and base but opted for an angled 1 inch ball with an angled hole that I screwed onto my handle bar at the clip-ons. I already had it and it worked great, much less bulky than the u bolt monster they sent me.
I have never owned a GPS before so its a fun toy to play with, and useful for when I finally start riding out of state this year. I done rode all the roads around here time to start multi day tripping!
I just plugged it into the switched fuse block/ground block I have already installed long ago and secured the wires with zip ties.
Radar Detector
I had a cheap Bell last summer that was worthless, I don't have the budget for a Valentine and saw this inexpensive Whistler remote radar detector on the net.
Radar Detector Includes Remote sensors - radar and laser - various mounting tabs
Whistler DE3500
I like the idea of a remote sensor since there is not many places to mount a radar detector on a motorcycle, this unit has a weather proof radar detector and a remote laser sensor.
Remote radar sensor mounted
Bolted on I used RTV sealant, brass screws, double nut pinch tightened, with rubber washers to protect the plastic.
1 inch drilled hole removed the headlight and drilled a hole for the laser sensor.
laser sensor
laser sensor installed The 5th gen light housing has a third light notch in the middle I used that space for the laser sensor it sets back in a bit and out of the head light beams, getting a full 180 degree sweep for laser detection and stealth.
Mounted it came with a metal mounting tab that I screwed into the base, then I used a rubber tire patch to cover it with and sealed the whole thing tight with RTV silicone.
Front view of both sensors
This unit has a temperature probe and also displays the battery voltage when programmed to do that. I like that feature to monitor my RR when on the road. My beef with this thing is that when I finally got it mounted and plugged into the fuse block it would not communicate with the remote sensor, I had to move it around and play with wires and test them for continuity. I also don't like the sound plug, you have to use this proprietary speaker that gives voice alerts for another $40 bucks, F-that I soldiered a couple leads to the speaker and made a little sound lead for it myself, works great.
Both the GPS and the Radar detector are wired into my mixer isolator box I bought off the net. It was available for a short while but is no longer being sold?? Its just a box with 2 mono inputs and 1 stereo input with a jack for my ear-buds. It mixes the sound and isolates the signal so it wont damage your electronics. I like it but it cuts my mp3 player output in half I have to crank it up to hear it. Its nice to hear the radar detector and listen to music on the slab, now my gps tells me to turn here and there too with a fake computer voice. I had a link to the mixer box in the links section but the guys website disappeared so I think he went out of business, its a simple little box solid state isolator mixer, no frills unit. I have my mp3 player attached to the right side master cylinder its easy to adjust volume and flip songs/mute.
Hey now I AM A GEEKED UP VIFFER FOR SURE NOW!
Dash Displays Whistler DE3500 Remote radar Detector, Garmin Quest GPS unit
GPS
Garmin Quest
Radar Detector
Whistler DE3500
laser sensor
