VFR Peg Lowering BLS...
30 posts Started 16 Jan 2006 Last recovered post 22 Jan 2006 Wayback Machine snapshot 18 Oct 2006
[image: Click for full size]
I'm drafting a engineering drawing for a CNC shop to bid on the design... then the
price will be announced and first batch of blocks will be offered to the members on
the list... questions???
[image: user posted image]
VFR peg lowering blocks are done and I happy the way they turned out...
The pegs tuck in nice and tight...
The design drops the peg to 1.5 inches right in line with the stock position...
Side by side comparison of the two designs showing the difference of the peg position...
Next weekend... weather permitting... VFR05 will truck his VFR up to the BLS and we'll
start testing...
Once the design is finalized it's off to a CNC shop for a run of 25 sets... price shall be
announced soon after and you may start ordering... questions???
Update...
VFR05 arrived at the Busy Little Shop and we had a nice visit... We bolted up the
blocks and found that the side stand touched when retracted... I milled off some
metal and got the stand to raise up higher but the stand still comes to a rest on the
block... it is so close to full retraction that we deemed it good enough... take a look
at the pic and you be the judge...
All in all the test went well but I'll turn over the rider impressions to VFR05...
That is a 6th gen shown (I think).
Is it also good for 5th gen?
Is it also good for many other Hondas (I believe Honda uses the same pegs on many bikes)?
All I need is a price and your PayPal ID Larry!
I like the way they are not moved forward any, so reach to the foot controls remains the same.
By the time one replaces the footpeg feelers with a short allen-head bolt, you would probably only lose about 3/4" of ground clearance.
Can I get the 2nd set since I kinda started all this when I posted my MCL lowering brackets?
I too am interested. Just waiting on the price.
Is there enough adjustment in the brake lever and shift lever? I did the Buell mod which dropped my pegs about an inch, and it seemed like at that point I ran out of adjustment on the the brake lever. Can you tell if the realtionship between the footpegs and levers will be the same as stock?
Nice work, by the way...
BLS...great job! I responded in an earlier thread when you were machining these that I wanted in on the buy, but in case you missed it put me down for a set. Thanks. Ron
Damn, Larry, you do NICE work! That's eye-candy!
Lobster, Jan 16 2006, 02:05 PMIs there enough adjustment in the brake lever and shift lever?  I did the Buell mod which dropped my pegs about an inch, and it seemed like at that point I ran out of adjustment on the the brake lever.  Can you tell if the realtionship between the footpegs and levers will be the same as stock?
You can remove the locknut and grind down the threaded shaft on the brake lever. I think HS did a write up on this. I did it to my 4th gen and it lowered the brake lever another inch or so. If that's still not enough you could heat and bend the lever.
BusyLittleShop, Jan 16 2006, 12:47 AMVFR peg lowering blocks are done and I happy the way they turned out...
i'd like a set.
Is Pay-Pal OK?
tok tokkie, Jan 16 2006, 01:23 AM
I'll need to get hold of a 5th gen to know for sure if the blocks will fit or not...
BLS, your inbox is full....
veefer800canuck, Jan 16 2006, 01:34 AM
After VFR05 and I test the blocks... I should have the answer to the amount of ground
clearance loss...
Mr Pheer, Jan 16 2006, 01:35 AMCan I get the 2nd set since I kinda started all this when I posted my MCL lowering brackets?
Mr.Pheer...I want to thank you for your MCL post... and you're good for one set out
of the first batch...
Flailer, Jan 16 2006, 11:08 AMi'd like a set.
Is Pay-Pal OK?
You're on the list for a set and yes PayPal is OK...
How much are these worth? Sorry if I missed that part...... Looks liek a nice addition.
That's great! Please add me to the list for a set. I never liked the look of the buell pegs.
Kanadian Ken, Jan 16 2006, 01:18 PM
To be announced... do you wish to be added to list???
imortlfool, Jan 16 2006, 01:30 PMThat's great!  Please add me to the list for a set.  I never liked the look of the buell pegs.
Thanks imortlfool... you're on the list...
BusyLittleShop, Jan 16 2006, 06:13 PMTo be announced... do you wish to be added to list???
sure - I think this is a great idea.
BusyLittleShop, Jan 16 2006, 12:02 PMMr.Pheer...I want to thank you for your MCL post... and you're good for one set out
Awesome! Just let me know the price when you figure everything out and I'll have a Paypal to you asap.
Larry didn't know if you added me to the list, pm'd you and did not recieve any thing back. But put me on your list if you would.
vince
gmicklus, Jan 16 2006, 03:35 PMI too would like a set  +1.gif
Thanks gmicklus... you're on the list...
Blue Viffer, Jan 16 2006, 04:08 PMLarry didn't know if you added me to the list, pm'd you and did not recieve any thing back.  But put me on your list if you would.
vince
Got it vince and I did send you a reply... you're on the list as well...
Please put me in for a set!
Thanks and great work!
looks fine to me... go for it
Please put me on the list.
Regards
Dave
Forgive the newbie question, but why lower the pegs? Confort?
BusyLittleShop, Jan 22 2006, 06:38 AMUpdate...
I too would like a set. Thanks Steve Roby
End of thread · 30 posts recovered Wayback Machine snapshot 18 Oct 2006
