#1 Thread starter
[image: gallery_491_221_137558.jpeg]
Blue Sea Fuse Block and Relay
I'd been intending to tidy up my wiring 'sometime', and needed to fiddle with the VFR. With the aborted purchase of a new windscreen, there was now a hole in my fiddling schedule, so I decided to move the wiring tidy-up forward to this weekend. I'd already decided what I wanted, and where to get it. There's a marine services place a few blocks from my new workplace, and I knew they were stockists of the Blue Sea products, and that they had the 5205 in stock.
The 5205 fuseblock is ideal for the VFR, as it has a negative bus, so accessories can be wired solely to the fusebox, instead of hunting for likely places to ground electrical items. Furthermore, it is very compact, robust, and well thought out. I had toyed with the idea of buying a 5206 instead, with 12 fused connections, as it is only slightly bigger and would still fit under the VFR's seat, but decided it was unlikely I'd ever have more than 6 items needed a fused connection. I also toyed with using the 5206 and moving the existing OEM fuses to it, but decided that would open a big can of worms, with having to lengthen bits of the wiring harness and whatnot. It hasn't caused any problem to date, so I left it alone.
So, here's the underseat area pre-install:
[image: BS_before.jpg]
Here's what needed to go under the seat:
[image: BS_bits.jpg]
"The bits" included an accessory socket, fuse box, quick-connect plug for my battery charger, and a relay to hook the fusebox to the battery via the ignition circuit, so it would be active only when the key was in the "ON" position.
I'd previously installed dual Fiamm AM80 Super horns (in conjunction with the OEM horn), but had neglected to put a fuse in, knowing that 'sooner or later' I'd get round to doing this fusebox install. The R/R fan (see below) had a fused connection in the tail cowl, where the fan ran off the taillight. I removed the fuseholder and negative connection from the tail, and used the positive one as the trigger for the relay.
Here's a pic of the R/R fan:
[image: BS_fan.jpg]
I personally don't think the fan will prolong the R/R's life significantly, but installed it because (i) I like to fiddle, and (ii) we had a heap of them lying around in our basement. It's screwed (into holes I drilled in the R/R heatsink) using two 50mm stainless screws at the top, and held at the bottom with a zip tie.
I toyed with the idea of mounting the accessory plug (cigar lighter socket) into the fairing, and also with using a marine power socket instead, but decided that I liked the idea of having the power socket stowed under the seat, because it meant I could locate it wherever necessary on the bike (like in the tankbag) for items like a GPS, or have it under the seat in wet weather. Also, rather than have to get an adaptor for things like my tyre pump, it was better to stick with the socket I had. Saved money too...
All the connections I made were crimped and soldered for security, as I'm not a great fan of the effectiveness of either of my crimping tools.
The relay was a standard 30A horn relay, with 40A capacity. Rather than risk problems with shorts or water ingress (and to save time!), I used a pre-wired relay base plug, but used a jeweller's screwdriver to slide the 'power in' terminal out of the holder, levered it open, and replaced the wire with a thicker one with a waterproof fuseholder and 30A fuse. I soldered it up, and slid the terminal back into the holder. I then zip-tied the holder to the relay, and covered the two with a length of bicycle innnertube. The fusebolck is bolted to the undertray with stainless steel machine screws, with blue Loctite on the nuts. I had to cut two of the tabs on the undertray (used for a Honda U-lock) with a sharp knife to get the fuseblock where I wanted it.
Here's how it all looks installed:
[image: BS_after.jpg]
After I took this photo, I added a plastic shield to the crossbar under the seat, to stop the tool roll sliding into the wires to the rear of the fusebox. I constructed this from a cut-up black polyethylene icecream container, zip-tied to the crossbar.
Having the tail cowl off was also an opportunity to give things a good clean (the tail cowl was covered underneath with chain spooge and dirt), and to fix a few niggling things, like a missing grommet between tail cowl and taillight, and fit a new ground for my taillight flasher. I also replaced a taillight bulb (twice!) when I discovered one taillight wasn't going. Luckily the indicator bulbs are identical!
The install all went pretty well, except after I'd finished I decided to check the battery voltage: 11.6V. When I connected the charger, it wouldn't go (broken wire), and while mucking around with it, I managed to nearly set fire to it. Oops...
So I used my son's (more grunty) charger instead, and I now have some rewiring of the charger's quick-connect cables to do...
Also, I forgot until I'd finished that the bike has grip heaters! D'Oh!!
So the next project is to unravel the PO's install, and reconnect the grip heater wiring through the fuseblock instead.
Here's a final photo (close-up of the Blue Sea fuseblock):
[image: Blue_Sea.jpg]
Total cost was ~US$37 for the 5205, and about US$25 for crimp terminals, the relay, nuts'n'bolts and stuff like that there. There was an abundance of tools, solder, heatshrink, wire and stuff lying around so I didn't need any of that.
Time: took me all weekend, including shopping trips, fixing booboos, cleaning spooge off so my photos weren't too sucky, and standing around thinking about what I was going to do next...
[image: BS_fan.jpg]
