Kisan Signal Minder
3 posts Started 22 Jul 2002 Last recovered post 1 Oct 2002 Wayback Machine snapshot 22 Jun 2007
Installing Signal Cancel
http://www.kisantech.com
sales@kisantech.com
November 5, 2001
The signal minder is a unit that replaces the Mitsuba turn signal relay on your VFR
The unit can also be set so that if the brakes are engaged (at at traffic light) the signal minder will not cancel
[image: k01.JPG]
The unit cost $89 us at regular price
VFR Forum Members
10% off regular price
The unit automatically turns itself off, it can be programmed to shut off in 10 seconds to a minute.
If they get enough orders the discount could go to 20% off
[image: k11.JPG]
1-2 hour install time
Standard tools from the kit
Installation steps 1998-01 VFR
Click here to view steps better
Begin by removing the upper front faring
Remove the side bolts 3 on each side
[image: k28.JPG]
1
Remove the dash bolts
2 on each side
[image: k27.JPG]
2
Remove inside moulding one screw on each piece
[image: k05.JPG]
3
Remove the inside dash screws one on each side
[image: k06.JPG]
4
Remove the mirrors
two10mm bolts
[image: k07.JPG]
5
Take note of plate and rubber seal placement
[image: k26.JPG]
6
Remove outer screws
[image: k08.JPG]
7
Watch out the windshield snaggs, there are several plastic fasteners on the faring that need to be removed I damaged one of them, be carful when removing them (rod and splay type plastic fasteners)
[image: k22.JPG]
8
Carefully pull off faring, the headlight wires are attached, it is not nessary to remove it entirely just move it so you have room to remove the Misuba relay
[image: k20.JPG]
9
I just moved it out of the way enough to reach in and remove the old relay
[image: k09.JPG]
10
Here is the OEM relay hanging from a rubber mount
[image: k10.JPG]
11
Carfully remove it, it has a locking connector, it is hung from a rubber mount with a palstic hanger
[image: k12.JPG]
12
The Signal minders plugs right into the same harness, it comes with a velcro fastener
[image: k17.JPG]
13
I opted to go one further and zip tie it in as well
[image: k13.JPG]
14
I zipped tied it horizantal and vertical
[image: k14.JPG]
15
Close up view
[image: k18.JPG]
16
This part is optional if you want ot connect the brake input, remove the seat and tank (need to rout a wire from brake light to front faring)
[image: k29.jpg]
17
I tapped into the rear brake light using an inline tap as shown (Radio Shack $1.29 @ 4 clips)
[image: k16.JPG]
18
Tap into one of the rear brake lights, the left side wire that is( green with a yellow stripe and red dots) this provides 12 volts input to keep the signal minder from canceling while the brake is engaged
[image: k15.JPG]
19
Run a wire from the rear brake light to the front faring and connect to the bottom of the Signal Minder
[image: k19.JPG]
Follow the same steps backwards to put it back together, I found it was easier to put back together.
:cool:
Can this be done on the 2002 VFR?
Yes,
It is just a swap out of the turnsignal relays.  The relay is located behind the top cowling behind the dash.  It is just a simple plug and play device.
End of thread · 3 posts recovered Wayback Machine snapshot 22 Jun 2007
