#1 Thread starter
Installing Sargent Quick Release Pins
[image: user posted image]
Standard Honda "FrankenBolts" Difficult to remove
Sargent Quick Release Kit
Tools needed
Drill out the threads
I used WD-40 on the drill bit to keep the bit from overheating and melting the body work
Insert a washer on the QR pin like so
Plastic tubing needs to be cut to size, dont get QR pins mixed up. They will each be slightly different depending on how deep the threads are.
Mark the point where the QR pin clicks into place
Remove the washer and measure the tubeing to correct size
I used a tube cutting tool but a sharp knife will do fine
It is best if the tubing is a smidge longer than need be for a tight fitting QR pin
Install the tube and the washer like so, I cut the eyeglass holder in half then tied the pieces to the inside of the frame with a sailors knot
Finished Project
The eyeglass holder matches the cording on my Corbin seat (trick) I have seen another member who used an elastic cord and drilled an access hole I just let it hang out the side. No worries about losing the pins.
http://www.sargentcycle.com/acfastaccess.htm
- 2 QR pins
- rubber backed washers
- 2 clear plastic tubes (not visible)
- 2 zip ties (I did not use)
Tools needed
- Drill
- 1/4" drill bit for metal
- Screwdriver for bolt
- Knife or tube cutter
- pencil or marker
Finished Project
