#1 Thread starter
Got me a Fox Twin Clicker and jumped on the Slammer's installation of his Ohlins to get some ideas.
He took off the rear wheel, gas tank and the exhaust system to get at the nuts and bolts that needed to be removed, cleaned and painted the exhaust headers and lubed everything up before re-assembly. ?Absolutely the proper way to do it, hands down.
Now not to slam our Slammer (for he is of mechanical mind and stout heart ?:bow: ) and being that I am going for a ride today and had to get it done last night, I decided to opt for a lazy man's way of doing this. ?I did want to clean everything, which I did, and I did want to lube everything which I did also, BUT I didn't want to decompose the bike in the process. ?Time restraints didn't allow for it.
Soooooo ?--- ?with a beer in hand ? beer.gif , I sat back for about 5 minutes and just looked at the situation. ?When the effect of the mostly gone can of beer took hold on the one or two remaining neurons in the gray matter ?:idea:, the light came on.
Hey, said I, this can be done without taking off the rear wheel, tank, and exhaust ?------ ?Maybe.
So in I went. ?With bike on centerstand I supported the rear wheel with a block of wood. ?Not lifted, just supported.
I took out the bolt that holds the bottom eye of the OEM shock and then removed the other two bolts and the tri-angular side brackets that the shock and the linkage couple together with. ?I also removed the pivot collar (the dog bone looking arm that comes off the back of the engine).
The tank was raised but not removed (shaken not stirred) and all the nuts bolts and rubber pads up there were taken out of the way so I could get to the nut holding the top of the shock. ?That came off easily.
There was not enough room to maneuver the shock out from between the swing arm and the exhaust canister with the swing arm in the lowered position it was in so I lifted the back wheel way up into the wheel-well now that the shock was not attached. ?I chocked the wheel in that position and the old shock nearly fell out.
The upper "U" bracket that holds the top of the OEM shock had to be opened up about .050" to fit the new shock's bushing but that was no biggie.
So far so good.
I then threaded the Fox's remote reservoir up through the hole and out through the left side between the sub-frame and the chain guard for final mounting behind the passenger peg. ?The shock itself followed and I tightened the upper bolt to the frame to hold it in place.
I then cleaned and lubed all the bushings and needle bearings at all the pivot points in the lower section. ?All the places where bolts go through have bushings and when removed, there are needle bearings in the housings they reside in.
The side plates went back on but in order to get the bolt into the pivot collar you have to let the rear wheel down to meet it. ?That too was no biggie and when I was convinced I tightened up all the bolts and had the reservoir mounted I re-composed the rest of the bike dropping nuts and washers into the frame as I went (is there any other way to do it?) ?:doh: and with the help of an inquisitive wife, set the rider sag to a little over and inch as a starting point.
If my exhaust headers were in need of it, I would have painted them too but they weren't too bad.
This was the LAZY boys way of installing a Fox shock. ?I can't say if the other makes would fit in as easy as the Fox but you can give it a try and report back.
So far so good.
