[image: View Post]cigarbuf, on May 31 2008, 11:13 AM, said:
I didn't want to spend a fortune on saddlebags but I still wanted a securely attached setup with lots of capacity.
I did not want to spend a fortune on saddlebags either ... so when I saw "cigarbuf"s post I was very interested. I will rarely use saddlebags. But I did want the option available for some overnight trips.
When cigarbuf posted his diagram, I could see that he had it all sorted and thought out. I ordered my bags that evening from NewEnough.com. The next day I started scrounging for material.
I decided to fabricate my bracket from some aluminum that I had access to. The material is 1" X 1/4". It happened to have 6mm holes drilled on 50mm centers. (already thinking about camera mounting options) I welded the bracket up using "cigarbuf"s dimensions and angles.
I replaced the license mounting bolts with 20mm longer bolts. This allows me to remove the bracket without loosening the license from the mudflap frame member. I can mount or dismount the bracket in about 5 minutes with tools already laid out. I intend on only mounting the bracket when I plan on using the bags.
The bags seem to be of good quality and come with all the straps you would need to mount them securely. I can guarantee you that I will never remove the "removeable" rigid expanders after the fiasco involved in installing them. There was one minor stitching error in a seam on the bag that was remedied quickly with needle and thread. The bags are not waterproof, but do come with thick, snug fitting rain covers that I have no doubt would do an outstanding job.
The photos show my excellent results using cigarbuf's plan.
Unfortunately, my bag set-up came in just a little more expensive than cigarbuf's..... I have about $110 invested after nuts and bolts purchases.
Thanks for the great solution, cigarbuf.
http://farm4.static.flickr.com/3032/2569192492_89fd9db39f.jpg
http://farm4.static.flickr.com/3067/2568367453_eea372a6c1.jpg
http://farm4.static.flickr.com/3005/2568360463_c81e5f5541.jpg
http://farm4.static.flickr.com/3026/2568360377_a449e75e93.jpg
Here you can see clearance around the exhaust. I believe you could sit idling on a 100 degree day and not have any problems. At highway speeds there would definitly be no issues.
http://farm4.static.flickr.com/3188/2569185156_a9426128a7.jpg
http://farm4.static.flickr.com/3017/2568360219_12480a8c0e.jpg
http://farm4.static.flickr.com/3164/2568360089_1dccd67ab4.jpg
http://farm4.static.flickr.com/3025/2569184898_c87b88018b.jpg
The bags can be removed from the bike in 30 seconds by simply unbuckling 3 quick-release nylon buckles. The wife reported that the straps across the seat did not compromise passenger comfort. The photos show the bags mounted far forward. With a pillion, I would slide the bags back about 3 inches for more foot room on the passenger peg.
