#1 Thread starter
[image: heatseat11.JPG] border='0' alt='user posted image' /> I had an extra heat element from a Kimpex grip set, I thought why not make the seat a heated seat. I had planned on adding some padding to my old Corbin anyway, 50,000 miles of hard riding the padding has started to get worn where I normally sit I bought it used anyway who knows how many miles it actually has, it was getting worn.
Prepping the seat
Remove the seat and drill off the rivet heads
[image: heatseat01.JPG] border='0' alt='user posted image' />
I removed the rivets all the way to the pillion section then pulled back the cover, it was glued so I had to pull on it hard, the foam had to be cut with a utility knife in one place to keep it from ripping.
[image: heatseat02.JPG] border='0' alt='user posted image' />
I took my switch and taped to the seat where I wanted to place it to see if it had proper clearance, it was touching the plastic in one spot but that was the lip that goes under the seat I cut a portion of it away to fit the switch, I also put it far enough back that it would not scrap against my leg or the pillions legs. Here is where I drilled, left side (free hand).
[image: heatseat03.JPG] border='0' alt='user posted image' />
The switch comes with what looks like a switch blade for a paddle, I cut the top off and took a Dremel stone to it to round it off.
[image: heatseat04.JPG] border='0' alt='user posted image' />
Drill a hole for the wires
[image: heatseat05.JPG] border='0' alt='user posted image' />
Here is the extra piece of foam I added and the element on top, sizing and placement.
[image: heatseat06.JPG] border='0' alt='user posted image' />
I tested the foam with some contact cement to make sure it doesn't eat it, then slathered both sides and glued the element on, and glued the extra foam to the old foam.
[image: heatseat07.JPG] border='0' alt='user posted image' />
I cut a sheet of aluminum foil to help spread out the heat over a larger area of the seat.
[image: heatseat08.JPG] border='0' alt='user posted image' />
I spliced some wires together and soldiered them to the switch, taped it all up with electrical tape.
[image: heatseat09.JPG] border='0' alt='user posted image' />
I marked the part of the lip on the plastic I need to cut away, used the Dremel wheel for that.
[image: heatseat10.JPG] border='0' alt='user posted image' />
I had some button self tapping screws I used to fasten the leather back on, I used the rivet heads over again to act as washers.
The little button is the switch, the leather was already torn on the seat below it, Now it has hi off lo switch. It uses 20 watts on hi and about 12 watts on lo. Gets hot fast and you have to switch to lo or your butt gets too hot. HEH biggrin.gif
Prepping the seat
