I got one of Kanadian Ken's Solo Racks. All of Ken's products are top notch. Great fit and finish. I already had his fender eliminator on my 07 Anniversary Edition for it's clean looks. The Solo Rack falls more under the "Function Column". Well, let's begin the assembly process........... :fing02:
This is what you get (and like the fender eliminator, a shame to cover up the VFR cut-away......
These holes line up with your grab handle bolts.....
These holes are for attaching the GIVI lock plate......
You will need to remove these plastic caps from the grab handle allen bolts.....
Use a small screwdriver to carefully pry them off.....
This is what the caps and allen bolts under them look like.....
Next, get a 6 MM allen wrench......
Remove the 4 allen bolts holding the grab handles on........
All four have flat washers and look like this......
The threaded rear frame bosses will look like this after removal......
You will need longer bolts. I liked the thought of some 12 MM chrome bolts because of the really clean look, and better load spread with their larger surface. I saved the stock VFR flat washers and used them under them. I'm not sure what the Honda Part # is, but these bolts are the rear fender strut bolts for a VTX1300C......
You will need a 12 MM socket for these......
Very clean (IMO) look after using them......
Bolt on your GIVI mounting plate for your favorite GIVI box, and you're ready to go......
And with Ken's Fender Eliminator......
I chose a small Part # E-30 GIVI 30 litre capacity box. I've learned to pack fairly light, even for week-long trips. I went up and down Monteagle Mountain today riding, and going there to take pics of the Trail of Tears Ride. I could tell no difference, even with the box loaded. Ken's mount doesn't affect the bike's handling like the standard GIVI mount, because it keeps the weight over the rear wheel instead of off the rear of the bike. Only draw back is that you can no longer 2-up with a passenger.......Hence, "SOLO" rack. Really great product....Send Ken a PM, and get one, you'll be glad you did....... :fing02:
