Hey magi, not sure if I can elaborate any more, to try to assure you, but I'll try:
1) basically, I didn't put any fender on mine at all. Just installed the beefed up assembly that comes with the bags.
2) the cw elim isn't really "installed", honestly, it's just a piece of metal now that's now been used as a license plate holder, not at all in the way it was designed to fit. I just redesigned it for this application.
3) you could use any piece of flat metal to do the same, just bend it here and there and drill a few holes, nothing to it.
4) Not putting on the old fender doesn't cause any issues with structural integrity. remember, the fender is just a piece of plastic, it's not adding any support anywhere. I think you'd agree once you saw the bag brackets installed, all the plastic fender does is get bolted to the brackets and does not supply support, ie it just hangs on the brackets.
5) again, the cw elim no longer attaches to the bike the way it use to (on mine or anyone who uses it after installing bags), it can't, the holes it is designed to use are no longer available. So basically it's fashioned into a license plate holder instead of using the full fender, nothing more.
6) you just have to decide if you want to do without the fender (I have a hugger which helps, but you still get stuff underneath u have to clean occasionally), or cut up the fender (not a bad idea, I didn't have a dremel and the orig owner didn't give me the little bracket that the plate attaches to, although I do have the fender) or just put the ori fender on (I don't really like the looks myself, but hey, I don't mind cleaning underneath :)).
so yes, I do have the finaly answer, yes it does work, as a piece of metal that has now been fashioned to be a license plate holder, just as the pic shows. Let me know if I can help further, H
magi, Jul 12 2005, 01:51 PMDoes anyone have a final answer on whether this works, and how well?
There's a newer post from vfr03silver here http://www.vfrdiscussion.com/forum/index.p...ndpost&p=148779 that says it does work, and has a picture of his bike with it, but I'm wondering what other peoples' experience was.
