#1 Thread starter
I picked up my new top case last night, and tonight started the install. �All was going well until I came to installing the rear carrier base. �After tightening all bolts the base can still slide side to side. �The plate which the base mounts to has slotted holes. �The bolts for mounting pass through a nylon collar/washer on one side of the plate and a nylon washer on the other.
This leads me to believe this is the intention; to have the base and in turn the top case slide from side to side in these slots! �So either I've screwed up or there is some reason for having this small, 3/8 to 1/2" side to side freedom. �Possibly to allow for shifting of items in the case, so the case shifts slightly to prevent any damage? �As you can tell I'm grasping here, but I've checked this over several times and I can't see why they would use slotted holes and nylon washers otherwise. �???
Any help from someone who has done this install or has the top case would be great. �BTW, the case looks great and really suits the bike. �It should also go a long way in keeping my wife on the back, her feet came off the pegs the other day as I left a light......she wasn't to happy about that..... wheel.gif
