Been a long time since I posted so I wanted to catch up.
2002 6th gen that I purchased with just over 36k on the clock. After about 2 years of riding it as a commuter almost entirely I decided to have some fun. Fast forward to now and here we are. Bike currently has just under 71k. I track this bike regularly now and it doesn't see much if any street miles anymore.
Current setup:
Sebspeed custom triple trees
2006 Yamaha R1 front end (trees cut for stock width so no spacers)
DMr built forks to my weight with all the add-ons possible
EBC prolite rotors up front
Brembo RCS 19 brake master
Brembo RCS 17 clutch master cylinder with braided line
Brembo remote brake adjuster
Vfr 1200 clip ons
Switch pod delete on both clip ons with custom 3 button Ducabike pod for start/fuel pump on throttle side
cbr1000rr throttle with quick turn cam
Domino grips
Oberon slave cylinder
Core moto braided lines front and rear on a de-linked system
Vesrah pads
Vented pistons in front calipers
Ducabike Carbon brake vents
Ti predrilled for safety wire hardware on entire front end: all pinch bolts, banjos and standard bolts/nuts
Sebspeed windowed clutch cover
Sebspeed rear set adapters with Woodcraft CBR 954 rearsets
Laser exhaust with delkevic headers
Rapid bike tuner w/autotune and single wideband o2 - tuned for MS100 and 91 octane
111hp, 64ftlbs on MS100
1 down, 3 up Vortex sprockets with 520 chain
Healtech QS
Healtech speedo healer
Healtech gear indicator
F4i rear shock with remote res built to my specs by Jamie at DMr
Few carbon pieces for fun; dash surround, chain guard, front fender, filler pieces between seat and subframe arms.
Keyless fuel cap
As3 silicone hoses
Water wetter coolant
VFRness harness
Antigravity battery with Li reg/rec wired direct
5th gen stator
EBC clutch with heavy duty springs
4 complete sets of wheels;
6th gen rear/R1 front in hot pink
6th gen rear/R1 front in Fluo Yellow
CB1000R rear/R1 front in Fluo Blue
8 spoke rear/R1 front in Fluo Orange
Custom front upper with headlight delete for the track. I run a 55mm projector when I want to run on the street that I got from MotoForza.
The final piece is almost finished. Honda RS125 tail with custom aluminum subframe from Sebastian.
I'm sure I've missed a few things!
Now for the downside...
Engine is done! Toasted it Sunday at the track. 3 laps in coming down the back straight and starting to downshift I could hear it and it sounded very hurt. Set up to take the turn and as I started to lean in the rear stepped out a bit. Instant pucker, stood it up and went off track into the dirt to avoid a lowside because I had passed 3 on the brakes and I didn't want to end anyone else's day. Nursed it thru the dirt and back around, stopped to see what was going on and noticed smoke coming from the exhaust. Waved at the corner worker and he came over as I shut the bike off. Told him there was a good chance I had leaked oil on track cause I could see it on my left lower fairing, swing arm and my rear tire was shiny on the left side.
Crash truck towed me back to the pits and sure enough catch can was full of oil. Inside of fairing was soaked, rear set, kickstand, swing arm, tire were all soaked. Thankfully there wasn't noticeable oil on track.
So here's my question.
5th gen swap?
Newer 6th gen replacement?
What do you suggest and why?
Here is a shot of the bike. If you'd like to see more detailed shots of some of the mods let me know...
[image: 20210820_183104.jpg]
