VFR Discussion Group -> VFR recall
30 posts Started 7 Feb 2005 Last recovered post 9 Feb 2005 Wayback Machine snapshot 4 May 2005
I had my VFR looked at today with its 8000 mile service. Enclosed are the pics of the Honda paper work for the recall. Had no leakage and everything measured as it should be.
[image: Attached Image]
adamf18, Feb 7 2005, 08:30 PMI had my VFR looked at today with its 8000 mile service.  Enclosed are the pics of the Honda paper work for the recall.
adamf18, Feb 7 2005, 08:31 PM
any leakage?
Good stuff Adam, Thanks
But they say if your Vin.plate has a punch mark on it don't check or repair, it's already been done ! Yah, if I'm not mistaken they used a punch mark to show that the Alt. Recall has been performed :blink: maybe it's in a different place, but with all the clowns that work in half the shops out there it wouldn't surprise me that they will look at any bike that's had the Alt. Recall punch and say "Your bikes been check already" <_<
The other thing I noticed is that "1" 2002 VFR/A (ABS) bike #.......2M400536 is the only problem 02 bike(ABS equipped anyway). :huh:
:beer:
Ditto on the thanks Adam.
767fixer, Feb 7 2005, 08:45 PMany leakage?
Added it the first post, sorry. But I had no brake fliud leakage.
baileyrock, Feb 7 2005, 12:47 PMGood stuff Adam, Thanks
:beer:
I have a 2002 ABS with a vin that ends in 476 which is before the recall number for the "1" 2002 ABS that is recalled. I wonder what the difference would be since 2003 and 2004 are also affected. I did have the recall work done on the Alternator and Seat Rail and there are two punch marks on the frame at the front of the VIN. If the brake recall work is done, it shows the punch mark to be at the end of the VIN. At my dealer, all work is entered into the computer, so I don't think they will try to tell me the work has been done if my bike is affected by the recall. I'll just have to wait and see if my bike is affected. I checked the Honda Owners Link web site today and it still lists my bike as having no recalls.
My other question about this recall is if they find no leaks, nothing is done (ie: no parts replaced). Who is to say that a leak won't develop in a few months or so, then the dealer would say that the recall work was done due to the punch mark on the VIN. Makes you wonder.
Dave. :wheel: <_<
So I take it that the 05's are not affected.
Zero Obliquity, Feb 7 2005, 10:21 PMSo I take it that the 05's are not affected.
It doesn't state it on the recall but stand by, they might do it before it goes out the showroom floor.
I just called the dealer and he checked my vin (a 2002 vfr w/abs) and it apparently is NOT affected by the recall either. But since there is only one VIN identified as affected for 02 vfr's with ABS I suspect that someone at Honda Corporate put something wrong into their database and our bikes may possibly be affected as well.
Also, from someone else's post, if you read the recall note closely, you'll see that they put the "corrected" stamp on the VIN plate on the left side of the bike, while the other recalls have them stamp the "corrected' stamp near the VIN stamped number on the right hand side of the bike, so there should be no confusion.
vfrvtecdave, Feb 7 2005, 10:14 PMI have a 2002 ABS with a vin that ends in 476 which is before the recall number for the "1" 2002 ABS that is recalled. I wonder what the difference would be since 2003 and 2004 are also affected. I did have the recall work done on the Alternator and Seat Rail and there are two punch marks on the frame at the front of the VIN. If the brake recall work is done, it shows the punch mark to be at the end of the VIN. At my dealer, all work is entered into the computer, so I don't think they will try to tell me the work has been done if my bike is affected by the recall.  I'll just have to wait and see if my bike is affected. I checked the Honda Owners Link web site today and it still lists my bike as having no recalls.
<snip>
Dave. :wheel:  <_<
baileyrock, Feb 7 2005, 03:47 PMGood stuff Adam, Thanks
:beer:
Thanks Adam for the good info :)
I'm with Kevin & Dave on these vin's...what if your vin is say before: JH2RC461*2M401716 THRU JH2RC461*2M402149
would it be alright?
I guess I will take it to the dealer... (insert scratching head emoticon here )
The dealer told that they just recieved this recall and that we should start recieving mail from honda stating this recall.
adamf18, Feb 7 2005, 04:56 PMThe dealer told that they just recieved this recall and that we should start recieving mail from honda stating this recall.
Ditto on the thanks Adam. Good Work! I'm still hoping my bike isn't affected, although I'm not holding my breath. My rear brake is solid as a rock though. So are the fronts.
Dave. :wheel:
Jeepist, Feb 7 2005, 04:10 PMI just called the dealer and he checked my vin (a 2002 vfr w/abs) and it apparently is NOT affected by the recall either.  But since there is only one VIN identified as affected for 02 vfr's with ABS I suspect that someone at Honda Corporate put something wrong into their database and our bikes may possibly be affected as well.
Jeepist,
What dealer do you use in the SF Bay Area? I also live near SF and bought my bike at Cycle West in Petaluma. They are a small dealership, although there service department is pretty good, and they are the ones that did the other recall work on my bike.
Dave. :wheel:
Not a hijack - but as an aside...
I usually go to Cycle Center in Fremont since it is closest to my house.
-- Johnny
vfrvtecdave, Feb 8 2005, 01:18 AMJeepist,
Dave. :wheel:
For the first time my bike is not affected by a recall
:beer: :wheel: :beer: :wheel:
After reading the recall, I think I could have done most of this myself.
767fixer, Feb 7 2005, 01:45 PMany leakage?
Boy did I read that wrong I thought it sounded more like a commerical for Potato chips cooked in Olestra.
I had been riding my bike a couple weeks ago when we had some nice weather here in Colorado. I noticed break fluid leakage and the bike has been in the shop since (ordering parts). It's all coming together now... Thank the VFR Gods that this happened in the winter, and thanks for the info on teh recall! :beer:
DaveG
Denver, CO
04 VFR
MountainMan, Feb 8 2005, 04:04 PMI had been riding my bike a couple weeks ago when we had some nice weather here in Colorado. I noticed break fluid leakage and the bike has been in the shop since (ordering parts). It's all coming together now...  Thank the VFR Gods that this happened in the winter, and thanks for the info on teh recall!  :beer:
DaveG
Denver, CO
04 VFR
Where did you notice the fluid? I'm seeing some on top of the chain guard, in the middle of the decal area by the shifter. Just curious.
sportrider, Feb 8 2005, 05:57 PMWhere did you notice the fluid?  I'm seeing some on top of the chain guard, in the middle of the decal area by the shifter.  Just curious.
There is a valve for the linked braking system right above the decaled part of the chain guard. Take your seat off and the left side black plastic cover and look at it. the cover has two pull pins to remove it. Look for the leaks there, if there is one, take it to the dealer. Or it just might be a loose conection, try to carefully retighten it. Hope that helps
adamf18, Feb 8 2005, 06:02 PMThere is a valve for the linked braking system right above the decaled part of the chain guard.  Take your seat off and the left side black plastic cover and look at it.  the cover has two pull pins to remove it.  Look for the leaks there, if there is one, take it to the dealer.  Or it just might be a loose conection, try to carefully retighten it.  Hope that helps
Thanks! I'll check -- it's not a ton of fluid, but enough to want to diagnose the source. Perhaps they'll catch it during the tech bulletin inspection (I mentioned the issue when I dropped it off this am). Ride safe.
John
HispanicSlammer, Feb 8 2005, 10:21 AMBoy did I read that wrong I thought it sounded more like a commerical for Potato chips cooked in Olestra.
:beer: LOL :D
HispanicSlammer, Feb 8 2005, 03:21 PMBoy did I read that wrong I thought it sounded more like a commerical for Potato chips cooked in Olestra.
Oh my god it burns!!!! Is that blood? Oooohhhhh the pain, make it stop!
well acording to the vin# range my 04 falls into however ive yet to recieve anyting from honda nor does the owner link web site list any recalls yet i wonder whats up with that
snake, Feb 8 2005, 08:48 PMwell acording to the vin# range my 04 falls into however ive yet to recieve anyting from honda nor does the owner link web site list any recalls yet i wonder whats up with that
When I had my VFR services yesterday, the dealer had just recieved the recall. Honda has yet to send out the notices.
Any one else hads theirs done yet?
I just got my 03 VFR a month ago and the person I bought it from had no recall service done. The owners link does not list out any recall service. Does the Alternator recall apply for an 03 VFR non-ABS and are there any other items that I should be concerned with? I know that my VIN falls into the group needing the brake recall and I plan to take the bike in, once the salt is cleared from the road.
End of thread · 30 posts recovered Wayback Machine snapshot 4 May 2005
