I did a search and couldn't find an answer. What is the oil drain plug torque spec for my '97? I know the oil filter torque spec is 7 ft/lbs. I haven't received my service manual from Ron Ayers yet, and I am changing oil this weekend.
On my '03 the drain plug should be torqued to 22 ft/lbs and the oil filter should be tightened to 20 ft/lbs. I would think they would be the same between a 5th and 6th generation. Then again what do I know? :blink:
SilverBullet, Apr 6 2005, 12:19 PMOn my '03 the drain plug should be torqued to 22 ft/lbs and the oil filter should be tightened to 20 ft/lbs. I would think they would be the same between a 5th and 6th generation. Then again what do I know? :blink:
Nevermind... I am a dork. It says it right in front of my face in my Owner's manual: 7 ft/lbs for the filter and 27 ft/lbs for the drain plug... :joystick:
Yea for the earlier models its 7ft/lbs for the filter but some reason its 20 for a VTEC, shoot my wrench starts slipping off at 10, I cant get mine that tight??
End of thread · 4 posts recoveredWayback Machine snapshot 2 May 2005
