Hi everyone, I have a 2004 VFR800 ABS with very low kilometers in great condition. It has not been ridden for a few years, and has a full tank of fuel with fuel stabilizer. It has a Power Commander and O2 eliminators, but everything else is 100% stock, no PAIR valve mods etc. It has not had the wiring harness recall, or any other recalls etc. I'm going to install a brand new battery in the next few days. Last year when I tried to start it, the motor would turn over, but would not run unless I put a few drops of fuel into the intake, and then only for a short bit. This year who knows, but I’ll report back and thanks so much in advance for any advice you have!
2004 VFR800 ABS Starting Problems Likely
2 posts Started 8 Jun 2025 Last recovered post 8 Jun 2025 Wayback Machine snapshot 8 Jun 2025
Does the fuel pump prime when you turn the key to start?
Ignition spark at the plugs?
Fuel pressure regulator?
Blocked injectors?
Those are the things I would check
Sorry, grasping at straws here. I'm sure others with more experience will chip in.
End of thread · 2 posts recovered Wayback Machine snapshot 8 Jun 2025
