#1 Thread starter
Nr750 Wheel On A Vfr750?
15 posts Started 27 Jan 2007 Last recovered post 4 Feb 2007 Wayback Machine snapshot 24 Jun 2007
I wonder what the actual weight difference is between the NR and the stock wheel?
Hobie1dog, Jan 27 2007, 06:47 PMI wonder what the actual weight difference is between the NR and the stock wheel?
If the rest of the bike is any indicator, despite being made of lighter material it will actually be heavier. dry.gif
Hobie1dog, Jan 27 2007, 07:47 PMI wonder what the actual weight difference is between the NR and the stock wheel?
With the amount of bragging rights that comes with a NR wheel, it will be heavier fer sure fing02.gif
I know that the NR wheels are not the lightest or Thorsten Durbahn's 750 which was featured in PB magazine would have had them on it.
He used PVM wheels. His bike ended up weighing 345lbs. Just at 100lbs less than stock.
SAFE-T, Jan 27 2007, 11:56 PMIf the rest of the bike is any indicator, despite being made of lighter material it will actually be heavier. dry.gif
What are you trying to say, that the NR was too heavy, too slow, and too expensive?
They do make great museum pieces, though.
I'd be most surprised if the NR wheel is lighter than any VFR wheel, esp. the 4th Gen. Looking at JZH's pics it has a multi-piece hub assembly which probably uses steel for absolute strength so the actual spoke/rim section can be a bit lighter? But the 4th Gen wheel has a highly machined hub section which looks like it marries strength with low weight.
I'm sure he'll post up weight info when he can. I'll post the relative weights of 3rd and 4th Gen rear wheels (minus tyres) in the next day or two.
Oh, Safe-T, where are you? JZH needs you to airmail him a drive hub, custom made and all.
Make him a real deal. And If he can't handle it, let me know. Maybe that NR wheel is just too much for him. Maybe I should make him a deal and take it off his hands before he drives himself crazy?
Larry
VFRrider
Larry
VFRrider
vfrrider, Jan 28 2007, 08:35 PMOh, Safe-T, where are you? JZH needs you to airmail him a drive hub, custom made and all.
Larry
VFRrider
no worries! GLL429 got him covered! anyone who can make a chain using only master links should have no trouble installing a wheel smile.gif
767fixer, Jan 28 2007, 08:41 PMvfrrider, Jan 28 2007, 08:35 PMOh, Safe-T, where are you? JZH needs you to airmail him a drive hub, custom made and all.
Larry
VFRrider
WOW, that dude is in for over a $1k USD for an OEM rear wheel. Granted he'll probably be the only the VFR rider in the world with one and that's way cool but getting marchesini's or the like which GREATLY lessen unsprung weight and would have been money better spent IMO.
Now let's look at it from a posers point of view on display at the local hangout: What's more street cred: A carbon fiber OZ wheel or an OEM NR750 unit? hmmmm?
FotoMoto, Jan 29 2007, 02:51 AMWhat's more street cred: A carbon fiber OZ wheel or an OEM NR750 unit? hmmmm?
vfrrider, Jan 29 2007, 02:35 AMOh, Safe-T, where are you? JZH needs you to airmail him a drive hub, custom made and all.Well, maybe I could use some 12mm drive pins, if he's got em!
I really should be posting this kind of techie stuff on VFRD, but I hardly ever visit anymore (last visit was, er, last August) and I read the UK site every other day. VFRD is definitely where the hard core VFR techies hang out. (Even if some of them can't keep their gobs shut, eh Murray?!?) wink.gif
For the record, I have no idea how much the NR wheel weighs... Scratch that, I do have an idea, about 4kg, but this is not an accurate figure. I don't have an accurate-enough digital scale, so I had to use the digital bathroom scale (weighing me and then me with the NR wheel on my head), but the results were not totally repeatable. Yeah, it's a silly amount of money to spend on a bit 'o bling, but once I'd seen the wheel for sale at a do-able price, I just had to grab it. Then the only question was, what to do with it, and although all of my bikes probably qualify as "projects" in one way or another, my already slightly modified FP was the clear choice. As I've said elsewhere:
meEr, well, it is lighter, but that's hardly the point. Fitting a distinctive part from a legendary bike of which only 300 were ever made is just cool. Like the neon lighting and full-fur body kit I've already installed... cool.gif
I'm now sure I can use the RC30 hub; I just need some 12mm drive pins and a friendly machinist to install them!
JZH, Feb 3 2007, 09:11 PMI really should be posting this kind of techie stuff on VFRD, but I hardly ever visit anymore (last visit was, er, last August) and I read the UK site every other day. VFRD is definitely where the hard core VFR techies hang out. (Even if some of them can't keep their gobs shut, eh Murray?!?) wink.gif
unsure.gif Sorry about letting that cat out, John... glad to see you back on VFRD though fing02.gif
End of thread · 15 posts recovered Wayback Machine snapshot 24 Jun 2007
