I just received a Givi V46 topcase from Twistedthrottle.com. I'm using it on my '94 VFR with Givi's Wingrack and E41 sidecases. The V46 measures 17"L x 22"W x 13"D and will hold 2 full face helmets easily.
I would like to get a simular set up for my 97....once I get her back on the road from the off road adventure. My question is do the side bags hold a helmet? And does the rear case take up some passenger room?. Would there be room for a back pad and still fit a passenger? Thanks Brian
The E41 sidecases I have will hold 2 helmets each. I can carry 6 helmets with my VFR.
the upper rack is adjustable, so you don't have to give up any passenger room. There is a back rest available for this case and it should be no problem to use.
Your bike looks great! Nopw Ill have to find who has the best deal on this setup .... Well be twins ... only different hair colors .
I have the E360's, and though they are a bit smaller than the E41s, they can hold my Shoei -- IF you take out the (relatively useless) document holder. I removed the holder from one of my sidecases and left in the other (though I never use it for documents).
As SLO97 said, the regular Givi rack allows full passenger accommodations.
SLO, good thing you have the standard mirrors -- your bike looks almost exactly like mine! (Black, double-bubble, stock exhaust, Givi setup). Thanks for the post, I have been thinking about a topcase to go with my E360's and this is helpful.
Marc
End of thread · 7 posts recoveredWayback Machine snapshot 27 Jun 2013
