Here are some basics ride guidlines for everyone attending the TexasMac.
1. Read and use "The PACE". This is the type of riding we expect at the Tmac. Hanging off is OK(mostly faster groups). (from Sebs recent post)
2. Every rider should start with a FULL Tank of Gas. Fill up prior to showing up to the Ride Meeting/ breakfast Friday & Saturday mornings! Not gas up afterward its best to gas up at the end of the day then you dont have to worry about it in the morning!
3. Top off your fuel at every fuel stop No matter if it's only a gallon or two everyone! Stops are based on the group needs and distance between fuel stops, having to make an extra stop because some clown doesn't follow the guidelines is a very Bad thing.
4. Never pull off/ turn around/leave your group without telling someone. Signal somebody in your group what you are doing and why! Each group should never loose a member for any reason, communicate your needs and make sure your entire group stays together.
5. Do Not tail-gate other riders, there are thousands of blind turns in this area and the last thing we need is to have a rider make a great panic stop to avoid something only to be run over by the rider behind him! Leave a safe margin, but do not lag to far behind either.
6. When passing a car try not to piss them off or scare them , there are many of our friends also needing to pass this cage. Please try to respect everyone else out on the road, our sport depends on it. There will always be the one crazy cage driver, be careful and get around/away from them as quickly as possible.
7. Passing: Do NOT go just because the rider in front of you goes!!! size up every pass yourself for how much open road you can see, how much time you have, how much distance is availible to pass, do it safely and quickly. Dont make a pass that would be considered "close"!!! Passing cages will most likely be the most dangerous part of our event, please be cautious. It is not a race to pass cagers!
8. Pegs up at 9:00 am both days, please be fueled up, fed and be there early enough to get assigned to a ride group before 9am.
9. Never cross the centerline except to pass. If you have to cross/cut corners to maintain your pace, you are going faster than your skill level. If you can't stay in your lane your riding over your head! SLOW Down!!! Staying right of the line adds a significant challenge to most roads and is mandatory for sport riding's future. Don't crowd the centerline Always expect an oncoming car with two wheels in your lane.
Maybe more to come. :blink:
