#1 Thread starter
All the materials were free to me, so total cost was $0, my kind of deal.
As most can tell, I'm Mr. Frugal (made own backrest, made own luggage system, R1 RR for $20, etc.......), so when it came to wanting a chock for my lift, I knew I wasn't spending $200 bucks on one. So I got to looking at different designs and realized that they are quite simple in design and leave quite a bit of room for tolerances. So I embarked on designing my own out of some scrap steel from my work. I have built this chock to be completely adjustable, you can move the flapper gate forward for smaller tires, or back for larger tires, so anything from my dads goldwing, my buddies vtx and my precious VFR will fit in snug as a bug in a rug. Quite honestly, I have only known how to weld appropriately for a tick over a month, so my welds don't look to good, but I feel quite comfortable with their strength. My father-in-law left his MIG at my house, so needless to say, he may not be getting it back. All that is lacking at this point is my McMaster shipment with the rubber feet to keep it from sliding around on the floor. Enough with the small talk, on to the pictures.
Here is the chock, you can see the giant gusset to keep the front channel from wanting to rock forward. Also my Flapper pivots in bronze bushings, so it pivots quite smoothly.
[image: DSC03803.jpg]
Here you can see how the tire clears the gusset, and how the stiffening angles welded to the bottom channel cradle the tire.
[image: DSC03805.jpg]
[image: DSC03806.jpg]
And here is where I prove that I do in fact have trust in my quasi welding skills.
[image: DSC03808.jpg]
[image: DSC03813.jpg]
[image: DSC03816.jpg]
I'd be happy to help anyone out looking to do something similar. My only complaint is that I wish I had my pivot point somewhat lower so there wasn't such a hump to roll over, but that would also compromise the "over center" design.
UPDATE:
I just attached a .zip folder containing an AutoCAD 2000 detail and assembly drawing of the chock. It is pretty basic, as I don't have too much time tonight. But feel free to ask any questions.
A few notes about the drawing and assembly. You can certainly change the assembly process any way you want, however I'd keep the main geometry the same. All material is formed .125" flat stock unless otherwise noted. You'll see where the bottom main channel has the flanges coped off so that the web of the channel slides under the cross support channel. I probably wouldn't do this if I built it again, I was trying to get more surface area to weld, but it is plenty strong and it makes an elevation difference between the cross channel and the main channel. The two angles running parallel on the main channel should probably not be placed by my dimension, set them by the way the tire falls into them (get the chock fully assembled, then roll the bike into it, place the angles along the bottom so that both sides are touching the sides of the tire and mark, remove bike and weld them into place). You can see in the pictures that I didn't do this, and forgot to take into account the metal thickness of the flapper gate. Also if you look closely at the pictures, you will see the shaft going through the bronze bushing, to keep the bushings locked in place and she shaft pinned inside the bushings, I used a 5/8" clamping set collar on each side. This also lets you take both set collars loose and slide one bushing out of the hole and remove the flapper from the channel. On the flapper, where the gussets weld to the side with the hoop, I had to bend that portion forward some, You can see the bend in the pictures, if I had left it straight, only the bottom hoop would have contacted the tire. This however is not a calculated bend, I simply slowly bent until it fit the radius of the tire. Hopefully this makes sense to you, if not, please ask any and all questions.
Also if you need the file in something other than a .dwg, about the only thing that I can do for you is make individual .pdf's of each part, but it will be a few days before I am back at my work computer with adobe on it.
When my Mc.Master shipment comes in, I'll take a few more pictures of the bottom with the bumpers installed and such.
UPDATE:
