#1 Thread starter
Bike is a 1999 Honda VFR Interceptor. Purchased it this summer while in Virginia. Test rode it but never got to really ride it till we got back here and I could tag it. The very first time I rode it, it overheated, got all the way up to 250. It was a slow progression, took about 15 miles to get there in about 40mph traffic. Parked it and trailered it home. Looked on internet and saw lots of comments about how VFRs have an issue with running hot. Something to do with the fact that the radiators (2 of them) are on the sides of the bike where they don�t get the best air flow, but obviously 250 is not just running a little hot.
A bike mechanic relative told me to change the thermostat as he thought it sounded like the thermostat never opened. So I changed the thermostat which was a total pain in the ass as it sits below the throttle body which has to be removed to get to it. So I changed the thermostat and filled the bike with all new Honda 50/50 coolant. Started the bike and just let it run. It slowly got hotter till it hit about 218, then the fan came on and dropped the temp to 198 or so. I then allowed the bike to do this one or two more times. At this point I thought I was good. NOPE! About the second time I rode it, it got hot again, and the fan never came on. So I talked to a bike mechanic who tells me bike thermostats almost never go bad, it�s probably the thermostatic switch which turns on the fan. So I replace it, fill it back up with coolant. Once again I�m good till about the second ride where it heats up again.
So now I say screw it and take it to Metrictech in McKinney. He puts it on dyno after filling the coolant just to see if the fan will come on, it does and he lets it cycle like 10 times. He says he just thinks I had an air pocket in it. Bike was good for one ride or so then it gets hot again, around 235 without the fan ever coming on. So now I�m really pissed. To make a long story short I ended up taking off the fairings so I could see the coolant system, hoses etc and the reservoir. I mark the level of coolant in the reservoir, it�s at 1in deep. I then take it on a ride. As soon as I get on road (about 2 min) I gun it pretty hard, probably hitting 10,000rpm or so, I look down and the coolant has already raised up another inch or so in the reservoir, the bikes only been running for 3 or 4 minutes!?
So I start wondering if it is only because of gunning the bike so hard. So I take it easy for the next 10 miles, the reservoir level doesn�t change a bit. So I gun it again, getting to 60mph as quick as possible, look down, sure enough, the coolant is up another inch or better. So I go cruising down the highway first at 5,000rpm (about 70mph) for about 5 minutes, the reservoir level doesn�t change, then up to 6,000rmp (about 85mph), still it doesn�t change. So now I know that what has been happening all along is that when I rev the bike real hard, the pressure is increased in the coolant system and coolant is sent to the reservoir, but this only happens when hitting 9,000 to 12,000rpm, or when gunning it from a stop where it may only be hitting 7,000 or 9,000, not totally sure.
So mechanic tells me that hopefully it�s the radiator cap, if not it could be a head gasket or warped head allowing compression to leak over into coolant system. I changed the radiator cap and this lowered the level a little, of how much coolant was moving from coolant system to reservoir, but it still was sending coolant over. Now in talking with the mechanic and a few others, it sounds like it is unlikely that it is a head gasket or warped head, as, if this were the case, it would probably be producing so much compression, it would be blowing off hoses etc. Or I would be seeing an oil leak or oil in the coolant. With the new radiator cap I was hitting the redline around 12-13,000rpm going from stop to 100mph in like first three gears; that�s a lot of frigging compression, I would think a head gasket or warped head issue that is allowing compression to leak into coolant system would have blown something up. Instead it raised the reservoir level about � inch, maybe 1in.
Now to give a little history on the bike, the individual I purchased the bike from had laid the bike down on the right side, probably doing 5 to 10mph. He said the mechanic replaced the fan and the right side radiator, the thing is, the bike has two radiators, one right one left, and only the left side has a fan attached. But it is possible that he damaged the fan on the left side radiator and the right side radiator. What I can say is that after I bought it and got it in the garage, I noticed over half the fasteners were missing. I called the seller to ask him where they were and he said the mechanic said that any missing fasteners flew out when he dropped it. BULLHOCKEY. Yea sure maybe the plastic fasteners, but where the cowlings are not broken, and the rubber/nuts are in place and not stripped, I don�t think so. So anyhow it�s very possible the mechanic was a douche, or the seller, or both (most likely option).
I am about to pull my frigging hair out with this. I do not want to get heads resurfaced if it is not needed. I�m looking for anybody who might have any input on this.
