#1 Thread starter
I've been fiddling around with my minidv cam for the better part of this year, and decided I wanted to try some new views. But I have to be different. So instead of hanging it off a fork leg, duct taping it to a fairing or saddlebag, or mounting it on the tank (like I have been), here's what I came up with.
My main goal was to get a view that included me in the frame, so I could evaluate my body position on the bike, which meant I had to mount it behind me. Doing this offers the bonus of having a clear view out the back of the bike, so objective B was to be able to spin the camera around on the mount for rear-facing video. I thought the best idea for that would be to come up with a mount that bolted to the stock seat cowl on my VTEC.
So, I need a plate to mount the camera to, a base plate to attach securely to the seat cowl, and something relatively stiff in between that wouldn't be affected too much by changing air streams(wind buffeting).
Lucky me, I work in a high-end sheetmetal shop... after doing some sketching on the ole' mental notepad, I gathered up some titanium scraps and had at it.
Tacked together:
[image: 11-27-07001.jpg]
Ready to add a little filler:
[image: 11-27-07002.jpg]
Done.(see the motivation on the wall? wink.gif )
[image: 11-27-07005.jpg]
That would be the mid section, the stanchion between the two plates. .080" 6-4 titanium. Very stiff, and pretty light.
I needed a strong block that would provide a mounting point for the 'ladder', and that would spread forces of movement over the base plate - I used a piece of scrap 1" aluminum, squared up on a mill.(I used the same block to space the ladder while I tack welded it together, for a tight fit). Here it is getting some holes drilled in it:
[image: 11-27-07012.jpg]
And the corresponding holes in the ladder:
[image: 11-27-07013.jpg]
[image: 11-27-07014.jpg]
Gives me this:
[image: 11-27-07017.jpg]
[image: 11-27-07018.jpg]
[image: 11-27-07019.jpg]
[image: 11-27-07020.jpg]
[image: 11-27-07021.jpg]
[image: 11-27-07022.jpg]
The base plate will be larger than the piece of cardboard shown; I just needed something to set it on for the pic. It will be about the same width, but longer towards the front of the bike, possibly with some strategic cutouts.
To add some flexibility to the setup, I drilled a third hole in the block, allowing the ladder to angle towards the rear of the bike to almost 45 degrees. I folded the ladder back until the first 'rung' hit the block, then tightened the bolt and drilled the third hole. Should be real stable in that position, it should give a better view when the camera faces back, and should catch the sounds of the exhaust and throttle changes this way. musik20.gif
[image: 11-27-07024.jpg]
[image: 11-27-07025.jpg]
I need to do some trim work on the bottom and top of the ladder, to allow it to swing to that second angle when mounted. I need to make the base plate for the seat cowl, and the mount plate for the camera. Then clean the parts and apply a finish that I haven't picked yet.
It will be mounted on this spare seat cowl that member Crazybrother offered up for grabs a little while back(thanks again dude!!). Dunno yet if I'll paint it flat black, red to match, or just leave it alone??? Decisions, decisions.
[image: 11-27-07026.jpg]
Now that the hard part is out of the way, I have the weather and road conditions to deal with; I may not get to test this thing out for a WHILE. I do know that if the minidv camera proves to heavy for the mount(it'll be very susceptible to acceleration and braking forces in that location), I'll get one of those small Oregon Scientific SD-card cameras that seem to be getting good reviews. Then I could run the dv cam on the tank mount, and edit both views together later... oh the possibilities!
Anyway, just wanted to share, get feedback, etc... I'll post more as I get it done. fing02.gif
Tacked together:
Gives me this:
