Banjo Bolt Bleeders
6 posts Started 12 Feb 2008 Last recovered post 13 Feb 2008 Wayback Machine snapshot 2 Jan 2009
Check the banjo bolt for the front brake master cylinder...
[image: bleeder.jpg]
I saw these on a VTR that was on eBay. Does anybody here know who makes them or where I can get them?
I can't see the pic, but it sounds like a double banjo Speed Bleeder. I have one on my F4i, they're very handy! fing02.gif
goodridge makes them, you just have to find out what size goes on the bike you wish to put them on:
http://www.motosport.com/street/search.php...t=badger-street
oh, i am not advocating this website as a source; it was just the first place i found a nice shot of the goodridge stuff. do a search on goodridge and you will have plenty of options.
Damn I want one.
My front brake mc (Brembo) has an integrated bleeder, but I have the bleeder banjos on both my clutch mc and slave. Anywhere that the banjo is at a high point, it makes things really easy. Mine, along with my custom-length lines, are from Galfer.
These are not the same as speed-bleeders, which have a check valve. I suppose you might be able to use a speed-bleeder with a bleeder bango, but I use a Mity-Vac for a dry system, then the standard pump-and-turn method to finish off, works fine.
Not exactly cutting edge stuff--they've been around for ages. I put them on all my bikes to make bleeding easier.
One tip: Don't use an alloy one like shown in the pic. Actually, I don't think the banjo bolt is a really a potential problem, but alloy banjo hose ends are a big no-no on a street bike, as they are subject to corrosion and breakage. Double-banjo bleeder bolts are also available in stainless and cad-plated. Mine are also Goodridge, but I think all of the major stainless brake line suppliers have them.
End of thread · 6 posts recovered Wayback Machine snapshot 2 Jan 2009
