#1 Thread starter
Resurrecting an old topic here, but . . .
This morning I started up the 1984 VF750F, pulled in the clutch lever and realized the lever was more ornamental than operational. I removed the clutch reservoir cover and saw that the fluid level was low - so low that the holes in the bottom are exposed when the bars are turned to the left lock. The line down at the slave cylinder bulges when I engage the clutch lever, so something is happening, but there isn't enough oomph to fully engage the clutch. So, I reckon I have air in the clutch line.
In your experience(s), is it worth filling the reservoir and trying to bleed the system at the top banjo bolt (where the line attaches to the reservoir), or should I just go to the bleeder valve and do the whole procedure?
