Clear Rear Lens Installed
31 posts Started 24 Apr 2008 Last recovered post 14 Aug 2008 Wayback Machine snapshot 10 Apr 2010
Just finished installing the clear rear lens along with Eagle Eye 3W LED turn signals all around and a new relay to keep the blinkers from blinking too fast.
I simply swapped the back of the lenses (since the turn signal holes are a different pattern). Put em both in the oven @ 220F for about 8 minutes and I was easily able to unstick the glue with a butter knife.
http://farm4.static.flickr.com/3286/2439899116_5ba946f5a5.jpg
Much better!
http://farm3.static.flickr.com/2383/2439076795_5e4605b87a.jpg
Brilliant! What did you use to re-glue?
Nothing. All of the glue pretty much stuck into the black backing... I pressed the new lens onto the old backing *hard* and held it for a few minutes while the whole thing cooled. Seemed good enough. If it ends up fogging up or something I'll figure something else out :).
Looks great! Where's the action footage? Need video!
Of what, blinking LEDs? I guess I could make a vid :).
Looks mighty nice and very clean. I may have to do this eventually.
Of what, blinking LEDs? I guess I could make a vid :) .
Those of us with no money to mod need to live vicariously through you all!
Ask and ye shall receive
http://www.youtube.c...h?v=-55jN2SxTzo
Very nice. See, what a difference the visual aid makes to the rest of us.
I've added this mod to the list for next year. Looking forward to your "how to" post (ehem, looking for) with pics, instructions and part numbers.
I found all the info from searching here. Just ordered from ServiceHonda.
mmmmm..... video......
Looks brighter than stock and the tail end of the bike looks much better with the clear lens...
Only thing I don't like about this method is that you end up with 1 useless taillight... end result always looks good though! :beer:
You could always install the mounts you didn't want and sell them to someone who needs a new one and doesn't care if it is clear.
[image: View Post]Kanadian Ken, on Apr 24 2008, 04:52 PM, said:
Used the oven? awesome idea!!
Thanks. I'm a car guy too and it's a well known trick to getting headlights apart to put clear turn signals in :).
....I just hope my wife isn't watching my flickr photostream, she won't like the look of motorcycle parts in her new oven :biggrin:
[image: View Post]klinquist, on Apr 25 2008, 07:24 AM, said:
I forgot that I made another video during the install... LED vs regular bulb in the front. As you can see, the brightness is actually about the same.
http://www.youtube.c...h?v=WRHH-FsaPYU
Now I've got you addicted to making video's.... lol
The one on the left seems to visually "pop" more to me than the right...
Yep.. you can get front clear lenses (Servicehonda), LEDs for the front (autolumination.com), and a turn signal relay (customdynamics.com) for about $120 total.
I really like. Already having the clear lenses, could list the part numbers in text of the bulbs and relay that you used.
Bulbs:
http://autoluminatio...m/7443_7440.htm
"Eagle Eye Tower - 7443 Dual Circuit - Amber"
Relay:
http://www.customdyn...ard_DOT_Flasher
It was plug-and-play on the VFR. Remove windscreen, pull front fairing up from the bottom (the piece on the front of the bike that the windscreen covers)... and the blinker relay is dead center. Plug in new relay, zip tie in place.
I'm just starting on my transition to clear lenses....But I was thinking, instead of baking/swapping the back of the rear lens, cant I just order 2 sockets for an 06-newer model? I disconnected the power connector from the socket and if this can work, this'll be the way I'm gonna go. And will this apply to the front as well? I like the shiny inside of the new lens backing compared to the dull silver on the old one so I'd like to use the whole lens.
And as far as bulbs go, is it a 7443A (amber) that I need? This bulb doesnt look that common, I'm thinking the dealership might be my only solution.
Sorry if this is hi-jacking your thread but I cant seem to find the pertinent info on this anywhere.
For both front and rear, the new style sockets have different connectors - so you'd also have to buy the bike/wire-side connectors and solder/clamp/whatever the wires into them.
The rears are actually just 7440 (single filament)... but 7443s will work fine too.
Well I took the rear lens and both backings from the front lenses to a buddy of mine who works at an autobody shop.
I was going to get him to swap the backing for the new rear lens but he suggested modifying the socket holes so the old sockets fit properly.
I picked em up this morning and this was by far the easiest/fastest way to get this all to work.
Now to wait for the LED's from customdynamics.......
I just picked up the same stuff for my 2006. Unfortunately, Honda seems to have switched to a 9-wire turn signal relay and the LED flasher that I got from customdynamics.com doesn't fit. Oddly enough, there's also a 2-wire relay (with a part # that matches Google searches for turn signal relay), but it's not getting any power. And when I disconnect it, the turn signals work. If I disconnect the 9-wire relay, no turn signals.
Just an FYI for 2006-2008 owners.
Sweet, it now looks like an 08. My 08 has those stock on it. The turn signals are still amber though. Can you show the pics of the leds that you used. Iwant to install the clear leds in mine but haven't had the nerve to remove the housing to pull out the ambers.
Now you gotta swap out the front turn signals as well.
http://www.vfrdiscussion.com/forum/public/style_images/light/snapback.png' alt='View Post' />klinquist, on Apr 24 2008, 07:17 PM, said:
Neat job. But I'd like to know about the top rack, especially with the oem side racks -- which model is it?
http://www.vfrdiscussion.com/forum/public/style_images/light/snapback.png' alt='View Post' />sportrider, on Aug 14 2008, 10:14 AM, said:
Looks to me like the OEM Honda top mount. If your lookin' for a aftermarket top mount to go with the OEM sidebags the SW-Mototech works and you can get different mounts to adapt to different brand cases. For instance I have OEM side bags and a Givi top truck that I can mount all at the same time and are all keyed alike since the OEM comes with an extra tumbler.
I did something similar with my car headlights. Looks sweet
End of thread · 31 posts recovered Wayback Machine snapshot 10 Apr 2010
