03 VFR, 20k miles, oil change 1000k ago, clutch fluid change 2months ago.
I've been getting this problem that has progressively becoming worse. It doesn't matter cold morning or end of 8 hour ride. This can happen pulling out from a stop or shifting into 2nd, or even 3rd. The lower the gear the more noticeable, obviously.
Here's what happens:
The action of pulling in the clutch, shifting the gear, applying throttle, releasing the clutch is where the problem shows up. At some point between applying throttle and releasing the clutch it's as if the clutch, itself not the lever, gets stuck. Meanwhile I'm increasing the throttle expecting the engine load to increase, and just as revs are 2k more than I'm prepared for, the clutch drops and the bike lurches. This is very embarrassing at a stop light, not to mention dangerous as I usually go about 3-4 feet before I halt the bike down.
Any ideas as to what this might be?
TIA,
Craig
TIA,
Craig
