I'm venturing to guess the main ABS fuse (the one in the right fuse box) is blown again (I haven't verified this, but this is what happened 500 miles ago... after riding down a gravel road). It came on during my commute - I did brake semi-hard for someone that pulled out in front of me... I wouldn't think it would he hard enough for ABS to kick in but maybe it did.
I guess I'm going to have to replace the fuse and then go into an empty parking lot and stand on the rear brake... see if the fuse blows whenever ABS engages. If that's the case, any further troubleshooting ideas? Replace the ABS computer thing? I guess I could check the ABS computer to see if has any codes stored (last time once I replaced the main fuse, the ABS light went off... are there codes that would be stored but that would not trigger the light?)
