Heya folks,
I sincerely apologize if this has been covered elsewhere, but from all the searching I've attempted I can't seem to find an answer on the boards (probably because "120" and "60" are too short of a search term, and "tire size" doesn't yield what I'm looking for), nor can i seem to dig up any info on those "other" VFR boards. :)
Basically, the front tire on my '02 is about done. Worn down the center, cupping, etc. A buddy of mine has a 120/60/17 Metzeler M1 that's barely used in his garage off his old Monster 750 that he says I can have if I want it. I know the stock size is 120/70/17, but are there any horrible disadvantages to a 120/60/17 tire? Most of what I use the bike for is commuting and the occasional mountain jaunt, and even then I don't ride terribly aggressive.
Opinions/thoughts? Am I going to completely mess up the bike's handling by moving to a 120/60 from a 120/70? Turn-in would obviously increase, but would the weight of the bike be an issue? Good idea, bad idea? Will the bike spontaneously erupt into flames? I don't see how it could make that much of a difference, to be honest, but I thought I'd run it by some others first.
As you can see I'd rather take a free tire that's nearly new instead of dropping coin on a brand new shoe, obviously.
