2007 Vfr800 W/ Abs Custom Dyno Mapped
10 posts Started 2 Sep 2008 Last recovered post 4 Sep 2008 Wayback Machine snapshot 2 Jan 2009
Bike: 2007 Honda Interceptor VFR800AS7 (ABS) 25th Anniversary Edition
Adds: PC III USB (Dyno'd Custom Map) w/ LCD Screen, Garmin Zumo 550 w/ XM Radio, Chatterbox GMRS X1 Bluetooth
Adds: Gastank Camera Mount, Factory Hard Saddlebags, Frame Sliders, Puig Double Bubble Windscreen
Mods: Two Bros Dual VALE, Removed all PAIR equipment & Hoses w/ Blockoff Plates Installed
Mods: Removed All Evap Equipment & Hoses. (All Mods Weight loss of 26 Lbs)
Just wanted to post what my mods have done and what the Dyno run had performed between the stock DynoJet mapping and the new custom mapping. This Dyno run shows just a custom fuel map change only for the PC III USB.
This map was custom done by an official DynoJet Research Tunning center.
Before: Running stock DynoJet 2006 Staintune Slipon Exhaust (Downloadable from DynoJets WebSite)
After: Custom mapped for mods done (see Above).
This custom mapping economizes cruising fuel utilization (<20% Throttle - Under VTEC 6600 RPM). It also optimizes performance for >20% throttle any RPM and all throttle positions with VTEC engaged (6600 RPM).
As you can see by the before and after the VTEC transition is smoothed out and it has added HP to the whole curve.
[image: 2007_VFR800ABS_Dyno.jpg]
If you want this map you can get it here: 2007_VFR800_ABS_TWOBROS_PAIR_EVAP.zip
Please note that this map has been tailored for a 2007 VFR800 ABS with a Two Brothers Dual VALE Exhaust. The PAIR Equipment was removed (with blockoff plates installed from Topo Parts and also complete EVAP Canister and hoses removed and capped at the throttle body intake.
I would like to thank Steve for perfoming the tunning for the custom map. His work really made the bike feel much better through complete throttle response and engine performance. It has to be felt to be believed. Weight Loss + More HP = Awesome Feel!
Sounds like you should be able to smoke (no pun intended against my bike that overheats) me when we go out and ride...
Hey Warren, I'd love to get a copy of your custom map.
Thanks in advance.
George.
Thanks for the write up and be sure to post the map. Too bad you weren't able to do a before/after mods comparo. I wonder what the dyno figures would have been before axing the pair valve and adding the after market pipe and PCIII. Your custom map is adding a total HP gain of 2.16, all of it above 8500. Torque increase is .6 ft lb, most of it also above 8500RPM. Every little bit helps, but I would imagine the smoothed out power delivery and the 26 lb diet (almost 5% fing02.gif ) is most of what your seat-o-the-pants-o-meter is feeling. I am curious as to what a dyno tuning session for the PC III costs.
Thanks for posting Warren, I could stand to lose those 26lbs right off the gut biggrin.gif
Good to hear your happy with the results of the mapping, now to the track wheel.gif laugh.gif
crazybrother, Sep 2 2008, 08:14 PMHey Warren, I'd love to get a copy of your custom map.
Thanks in advance.
George.
I added a link under the dyno graph to the map that was done.
RRW, Sep 2 2008, 08:17 PMI am curious as to what a dyno tuning session for the PC III costs.
I believe it is around $250-$300 for a full customized mapping on a dyno. The mapping was basically free for me since I won a raffle drawing to be redeemed at Las Vegas DynoTech and I used it for the custom mapping since I needed it.
knight4u872, Sep 3 2008, 11:36 PM
knight4u872, Sep 3 2008, 08:36 PM
RRW, Sep 4 2008, 01:00 AM
End of thread · 10 posts recovered Wayback Machine snapshot 2 Jan 2009
