Pls Verify: Brake Light Power Comes From G/y Wire?
3 posts Started 26 Sep 2008 Last recovered post 27 Sep 2008 Wayback Machine snapshot 12 Apr 2010
I'm installing some additional LED's on the rear. They'll flash when the brakes are activated. So the wire I need to tap for power is the G/Y tail light wire, correct? I've looked at the wiring diagram, but I'm doubting myself, so if somebody could just verify for me, I'd appreciate it.
The Green/Yellow wire is the Brake light power. You are correct. There are two lights and two connections (two Grn/Yel wires). One to each light on the same circuit.
Muchas Gracias!!!!!!!!!!!! :fing02:
End of thread · 3 posts recovered Wayback Machine snapshot 12 Apr 2010
