For those of you that have the 6th gen 'Tunes, do they include a heat shield for the down pipe that's near the pillion's right leg? The stock exhaust has one here, but I've never seen a pic of that part of the Staintunes. If anyone has such a pic, I'd appreciate a posting.
Cheers,
Tom
No heat shield with the 6th gen Tunes. I just sold my set - or I'd get you a pic. Was never a problem for me - except when the rear shock gave out - the up pipe melted a bit of the Powerbronze P.O.S. hugger......
No they don't. I melted my boot's heel cup to them every time I rode. Eventually, I purchase an aftermarket, universal heatshield from Wheeler's. It is a semi circular piece of aluminum with holes in it that attaches with hose clamps.
I've melted my boot to mine, too. Took a long time cleaning it off that stainless pipe but finally got it off. I'm just careful about my foot position when I ride now. I never put a heat shield on.
No shield......no problem here. Jeremy must have big feet........ :biggrin:
I've got size 14's (save the jokes, it's more common then you think!) and just mounted my tunes a couple of weeks ago. I did notice my heel hits the pipe and do notice it's hot however, I don't think it'll melt my boot. I've really noticed it in the cold (if 45 is cold) and I can put my leg and use it as a heater!! Really need to get some heated grips and vest before the winter gets here...
Never had a problem with mine not having a heat shield. I like the look of the pipe by itself. Never melted a shoe but I did melt a shoestring that came untied from a tennis shoe I was wearing.......always wear boots now...that melted nylon took forever to clean off. :rolleyes:
I've got size 14's (save the jokes, it's more common then you think!) Say what?!!! Size 14 is common? Man those are some big dogs. You are probably going through boots like crazy. The heel melts on the pipe and the toes are dragging the ground...all at the same time. Do you have footpeg extensions? HA!!! Sorry dude, I could not resist. I tried but damn, the image in my mind would not allow it. :biggrin:
Thanks for all the responses. I'm gonna pull the trigger on a set on Monday, but I will miss the look of the stock brushed aluminum on the pearl white bike. I think it's just a beautiful combination but, having had Staintunes on my '00 VFR and '02 Blackbird, I can't resist the forthcoming growl :biggrin:
I'm seriously thinking about fabricating a "u" shaped bracket like the one on the stock mid pipe to weld onto the Staintune pipe. Then I can mount the stock heat shield. I'll have to see if boot clearance will be a problem...I sport size 13's, so we'll see :unsure:
Cheers, Tom
http://www.vfrdiscussion.com/forum/uploads/1222746964/gallery_1153_4038_48592.jpg
