Sticky Throttle...
2 posts Started 7 Oct 2008 Last recovered post 9 Oct 2008 Wayback Machine snapshot 12 Apr 2010
Anyone have a remedy for a sticky throttle? It only seems to stick when it's shut completely. I have to twist it a bit harder to get past the sticky spot right off idle and then it's fine. Makes for some seriously lame throttle control.
grip touching the bar end weight? mine does,then it sticks till i push it up...just a thought..otherwise lube the cable and inside the throttle...and make sure no kinks..
good luck!
End of thread · 2 posts recovered Wayback Machine snapshot 12 Apr 2010
