Regards,
Bruckner
[image: View Post]Bruckner, on Oct 7 2008, 01:45 PM, said:
Anyone here running BT21 tires? I had the front changed about 8K miles ago last season, while washing the bike recently I inspected the tire and wear was exactly the opposite of what I was expecting: the middle section is protruding while the sides are clearly worn. Now, I know that these dual compound tires are designed to be softer on the sides and harder in the center, but knowing that I'm not an aggressive rider in the curves, the difference in wear seems inconsistent with the design characteristics of the tire. Anyone has a similar experience?[image: View Post]cruzinaz, on Oct 7 2008, 02:13 PM, said:
Anyone here running BT21 tires? I had the front changed about 8K miles ago last season, while washing the bike recently I inspected the tire and wear was exactly the opposite of what I was expecting: the middle section is protruding while the sides are clearly worn. Now, I know that these dual compound tires are designed to be softer on the sides and harder in the center, but knowing that I'm not an aggressive rider in the curves, the difference in wear seems inconsistent with the design characteristics of the tire. Anyone has a similar experience?[image: View Post]Wheatie, on Oct 7 2008, 02:45 PM, said:
Anyone here running BT21 tires? I had the front changed about 8K miles ago last season, while washing the bike recently I inspected the tire and wear was exactly the opposite of what I was expecting: the middle section is protruding while the sides are clearly worn. Now, I know that these dual compound tires are designed to be softer on the sides and harder in the center, but knowing that I'm not an aggressive rider in the curves, the difference in wear seems inconsistent with the design characteristics of the tire. Anyone has a similar experience?[image: View Post]Bruckner, on Oct 7 2008, 03:30 PM, said:
Anyone here running BT21 tires? I had the front changed about 8K miles ago last season, while washing the bike recently I inspected the tire and wear was exactly the opposite of what I was expecting: the middle section is protruding while the sides are clearly worn. Now, I know that these dual compound tires are designed to be softer on the sides and harder in the center, but knowing that I'm not an aggressive rider in the curves, the difference in wear seems inconsistent with the design characteristics of the tire. Anyone has a similar experience?[image: View Post]cruzinaz, on Oct 7 2008, 03:21 PM, said:
