[image: View Post]speedracer2235, on Oct 11 2008, 08:11 PM, said:
I do believe I will try it as well. I have been looking for a way to cheaply and effectivley change the suspension on my 06. As is the only way I can keep up with the ducati guys from my shop is to run them down on the straights and then late brake:(
What most end up doing with stock bike because the suspension blows through the travel so easliy, is run excessive preload to halt the brake dive and bottoming, or blowing through the travel.
This however ruins the cornering performance, cause its too stift on the supple stuff and doesnt corner right, cartridge forks are very sensitive to oil height changes, 5mm can mean a bike that works well and one that doesnt.
Excessive travel of the fork, also makes the rear much worse than it actually is, cause a front thats blowing through the travel, makes the rear end want to kick, especially when running 100 mph whoop sections.
This setup, provides supple accurate handling, dive resistant and soaks everything really well, you'd have to offroad it, to Flaw it IMO
Many of the race tech spring complaints of too stiff for the street, dont exist with this setup, and its pretty Damn good for $8 and your time and elminates all of the stock set up negativity issues.
I cant complain about anything fork wise with this setup , it does it all and its supple, resistive and accurate. With my last setup, i thought that was about the best the stock fork was going to be without throwing money at it (aliitle stiff on stutters) but better than stock, but I was wrong.
Let me know how it do
:biggrin: :biggrin:
