I downloaded a map that is for 2002-2005 w/catless headers(5th gen) K&N filter and staintunes.
Now my main question is I have motad headers and Leo Vince pipes with a K&N. Will this map work well with my bike. Or atleast better then the current on I have that is with or without stock filter and leo vince slip on's.
WC,
It's hard to tell without a Dyno run to compare the two. However, I think it should work better. Your current map was made for bikes with cats, which you no longer have. Fortunately it's easy enough to swap the two out as needed. You can do a 'seat of the pants' test for each.
Either way it's way better than the stock map... what a snatchy piece of junk.
[image: View Post]Pete McCrary, on Oct 29 2008, 02:52 PM, said:
Try Tinyminds map if you are running catless now. I am running it and am very happy with it.
Mr. Minds did a great job with the map.
I'm currently using Tminds and have also used Coyze's version 5 and both have worked well. :fing02:
I guess when all is said and done though, getting a dyno done by someone who knows what they're doing will be the next thing.....
End of thread · 4 posts recoveredWayback Machine snapshot 12 Apr 2010
