[image: View Post]SEBSPEED, on Jan 16 2009, 06:00 PM, said:
First off, Dmitry, if your main reason for buying that welder is to weld your VFR exhaust, step away. I have one of those little cheapy units and they work ok for making things stick together, but that's about it.
I welded up a bench out of 1/8th steel angle(actually old bed frames that I cut to fit). I had to weld on both sides to make sure it held.
The flux core wire used in this WIRE FEED WELDER makes a mess and the whole system in these cheap units is questionable.
A MIG welder(a welder that feeds wire out of the gun with shielding gas from a tank), is very handy to have and, when the right model is used, can handle a much wider range of material than the wire feed welder can.
In order to get good welds on anything over 1/8", you really need a 220v machine.
The welder you show above does NOT weld aluminum. Aluminum is welded using AC current, while steels are welded using DC current.
It is possible to weld aluminum with a MIG welder, although it is far from the preferred method.
I'm saving up for a TIG welder, I hope to have it ready to go here by mid summer. It's made by Thermal Arc and costs about $2200 after I buy the gas bottle and some filler rod.
I highly suggest you check out your area for colleges or vocational schools that offer night classes for adults. I took a MIG welding course a number of years ago, and we were allowed to bring items in for projects, the instructor allowed us to use some of the other machines also after he recognized us as being competent.
[image: View Post]Baileyrock, on Jan 16 2009, 06:19 PM, said:
[image: View Post]cruzinaz, on Jan 16 2009, 04:01 PM, said:
To do your exhaust you will need a Tig AND someone that has been trained, that welding job is not an easy one, I have done a few.
I have to disagree here as MIG's are prefect for exhaust system work especially with slip in or over lap work and you'll find them at most muffler shops as their main welder. Old school guys still us Ox/acetylene and do very well. :biggrin:
Now if you plan to hand build a set of headers a TIG is the only way to go especially for butt welding thin wall.
It is harder to fill holes with a Mig but doable. :blush:
I think it's easier to fill holes with a MIG? But I also prefer TIG welding aluminum over steel... most guys at work are the opposite.
An oxy/ace setup is a great thing to have, very versatile. Different tips for the torch allow a lot of choices for welding, heating, burning, etc.
SEBSPEED = Mr Wizard
+1
