Brown
[image: View Post]MakMan, on Mar 23 2009, 11:43 PM, said:
.....Granted this was for a Car, but his reasoning was essentially this - he told me that Honda uses a special Break-In oil (or at least did then - I haven't discussed it since) meant to specifically accomplish All of what BLS just described so effectively.[image: View Post]MakMan, on Mar 23 2009, 11:43 PM, said:
In fact (again, it was a Car), he Also said NOT to Change the oil Early, but to go for the Full service recomendation (or at least 5,000 miles, he said) so that the oil was able to do it's thing properly.[image: View Post]Bruckner, on Mar 23 2009, 06:04 PM, said:
I think it doesn't much matter how you run the engine, intuitively I would think running the wheels off of it as you would on a track could be counter-productive but that can't be done on the street. The manufacturer would provide instructions if necessary, Honda wouldn't risk having to replace improperly broken-in engines under warranty if a specific procedure was needed.[image: View Post]cornercarver, on Mar 24 2009, 07:09 AM, said:
I think it doesn't much matter how you run the engine, intuitively I would think running the wheels off of it as you would on a track could be counter-productive but that can't be done on the street. The manufacturer would provide instructions if necessary, Honda wouldn't risk having to replace improperly broken-in engines under warranty if a specific procedure was needed.[image: View Post]Bruckner, on Mar 24 2009, 12:54 PM, said:
Sounds good, although as with anything else I would stick to instructions provided by Honda. I'm a mechanical conservative, seems to me the people who designed these machines know how they work best. The number of conflicting theories I heard about these different breaking-in methods (let alone the requirement for a specific break-in procedure) make me doubt whether anything else than instructions provided by the manufacturer should be trusted. Is there anything about this in the owner's manual?[image: View Post]spud786, on Mar 24 2009, 05:29 PM, said:
Everyone keeps mentioning do what honda says, do you know what Honda says?[image: View Post]Pete McCrary, on Mar 24 2009, 06:58 PM, said:
You're breaking in big end bearings, wrist pins, main bearings, camshafts, valve/valve guides, camshaft buckets inside the cylinder head, transmission bearings, gears, water pumps, oil pumps, etc. There's a lot more parts whirling around inside an engine than just pistons and piston rings. Even the chain and sprockets/wheel bearings, etc need to break in.[image: View Post]BusyLittleShop, on Mar 24 2009, 04:41 PM, said:
That's just it... there is no evidence that the same engineers who designed the machine are the ones[image: View Post]Bruckner, on Mar 25 2009, 12:40 PM, said:
Well.. you may not trust Honda's lawyer talk, I'll speak for myself, who am I to speculate on who writes these service manuals? If I ever feel justified to question the validity of Honda's instructions on its own products, for sure I'll be even more scrupulous of random tuners/builders, especially when no two of them come up with similar conclusions.[image: View Post]cornercarver, on Mar 25 2009, 12:44 PM, said:
Bottom line for me (and since the original post asked for advice - I offered) is that many people swear by the mfg's recommendations without any reason why except "They made the bike/car/truck/lawn mower/snow mobile/weed wacker/chainsaw/cement mixer so they must know better than anyone else."[image: View Post]canib, on Mar 25 2009, 10:30 AM, said:
BLS � You are obviously the smarted man in the room. Thank you so much for the informative write up.[image: View Post]Bruckner, on Mar 25 2009, 09:40 AM, said:
I simply don't see how the input of attorneys would get Honda to censure a break-in procedure required for optimal performance.[image: View Post]BusyLittleShop, on Mar 25 2009, 11:51 PM, said:
I simply don't see how the input of attorneys would get Honda to censure a break-in procedure required for optimal performance.[image: View Post]Bruckner, on Mar 26 2009, 07:45 AM, said:
Very well. If I want to tune the engine, I'll find a good tuner. If I need to break an engine in, I'll follow Honda's instructions. That is until some consensus is achieved on a better way to do this. Fair enough?[image: View Post]BusyLittleShop, on Mar 26 2009, 10:40 AM, said:
Fair enough... but I think there is an consensus... the Honda Factory[image: View Post]Bruckner, on Mar 26 2009, 12:02 PM, said:
Interesting. What do you mean by "Honda Factory"? The technique you witnessed at the factory? I'd be curious to know why VFRs aren't properly broken-in at the factory as they do with other models as you report. Do dealers receive instructions from Honda when putting oil in and starting up for the first couple of times before handing out to customers?[image: View Post]newvfr2009, on Mar 29 2009, 03:33 PM, said:
I've just bought a brand new 09 vfr and am running it in. The salesman at the dealers said to 'take it easy with no full throttle blasts in gear, and don't go over 6K rpms until it's had it's 600 mile service'. I've tried to find out the best way to run it in, but as with most things you ask 10 people and get 10 different answers, so I'll just stick to what they said.[image: View Post]spud786, on Mar 24 2009, 05:29 PM, said:
Everyone keeps mentioning do what honda says, do you know what Honda says?[image: View Post]newvfr2009, on Mar 29 2009, 02:33 PM, said:
I've just bought a brand new 09 vfr and am running it in. The salesman at the dealers said to 'take it easy with no full throttle blasts in gear, and don't go over 6K rpms until it's had it's 600 mile service'. I've tried to find out the best way to run it in, but as with most things you ask 10 people and get 10 different answers, so I'll just stick to what they said.[image: View Post]newvfr2009, on Mar 29 2009, 01:33 PM, said:
I've just bought a brand new 09 vfr and am running it in. The salesman at the dealers said to 'take it easy with no full throttle blasts in gear, and don't go over 6K rpms until it's had it's 600 mile service'. I've tried to find out the best way to run it in, but as with most things you ask 10 people and get 10 different answers, so I'll just stick to what they said.[image: View Post]newvfr2009, on Mar 30 2009, 05:29 AM, said:
I am dying to rev it and feel/hear the vtec kick in. :biggrin:
