What Rear Suspension Setting?
9 posts Started 27 Mar 2009 Last recovered post 29 Mar 2009 Wayback Machine snapshot 12 Apr 2010
What are you guys using as a rear preload setting when carring a passenger?
I very rarely carry a passenger, but I have a cutie that wants to go for a ride tomorrow.
I weigh 230lb and I'm guessing her weight to be about 130lb.
I want to stiffen up the preload, but what setting would be appropriate?
Get that preload up as hard as you can, buddy :laugh:
Oh man, you can't do that when I'm sitting at work trying to not look conspicuous. Now everyone is wondering why I'm crackin up. LOL!
1st off: Don't let her read your estimate, unless she is clearly over that weight.
2nd: Just crank it up a couple rounds. If you have an ABS, it's easy to readjust if you're wrong. If not, I'd probably go as close to max as you can. Unless she's a noob, and then you probably won't be railing it anyway, but just takin it easy and showin her "around". In that case, keep it a little squishy for her comfort. She'll appreciate it.
Like rice said ....start with it as hard as possible...Then put your adjustment tool in a easy excess (tank bag etc.) place....Take your friend with you for a setting test.....Basicly if it feels to like it's taking bumps to hard....back off a click....Repeat until it's taking bumps without being to bumpy,or bottoming out (if it's feels bumpy,It's topping out)...Monk
I expect you are in need of a spring rate upgrade?? 230lbs is a bit over the stock spring's working range even before you put a passenger on.
Sounds like about what I weigh by myself !! ;)
Thats why I bought the Super Duper Ohlins that is unfortunately now for sale..... PM me, the $700 price tag might drop a bit. :)
Do you have your sag set at 35mm already? If so, I'd just bump it up one or two notches on the adjuster. Riding a passenger kills the handling anyway, so it doesn't really matter!
I only weigh around 210 with full gear and I keep the rear spring about 1 or 2 notches from full hard....
What you should do is remove the grab rails if you haven't already so she'll have to hold on to you!! I like the ladies that have a good set of air bags for their own cushioning between us! :biggrin:
End of thread · 9 posts recovered Wayback Machine snapshot 12 Apr 2010
