Took my vfr out of storage today and the FI light is on.
Dealer says 3 weeks til he will be able to look at it.
So I have plenty of time to putz with this.
Found this and a few other discussions on how to read the code.
http://www.vfrdiscus...;showarticle=16
These are for older 5th gen bikes.
I've pulled off the plastic and I don't see anything unattached which looks like the service check connector in the tail/under seat, on either side or upfront behind the head lights.
Would anyone want/willing/able to update the technical maintenance forums with the shop manual or instructions for this on the 6th gen?
scroll down and read the vtec procedure below the 5th gen procedure - find your fusebox its near that.
[/quote]
[/quote]
On the 6th generation bikes there is a 4 pin connector near the regulator. If you pull the socket the threads are black/white, orange/white, green and brown. On it your dealer will connect a handheld computer to read out the Electronic control Module.
I do not know if that handheld computer is available for owners. I would like to own one.
Your description of the
"4 pin connector with the threads black/white, orange/white, green and brown"
is what I saw originally but
I wasn't sure since the 5th gens and prior info shows a white 2 pin connector.
I was just out playing around with it and noticed that if I turn on the ignition,
without any jumper wire,
the FI light appears to be flashing a code.
It looks like a "24";
#2 O2 sensor heater faulty.
Now to find my warranty info.
End of thread · 5 posts recoveredWayback Machine snapshot 12 Apr 2010
