Anybody know if pc for an 04-05 will work on an 06-XX are the harness plugs the same.
The only difference I'm aware of is the vtec cut in rpm which has nothing to do with the pc which only does fuel/air but pc site lists different part numbers.
The same thing happened with my CBR1000RR 04 but different listing 06 but works fine & even the 600 works so long as plugs the same.
Yeah, it's works fine. Just download a map for your year. I use the stock map from PC, for my '06. I took the PC off of my '05 after the crash. :blink:
The part numbers may be listed different if they come preloaded with a map. Obviously the maps are different.
Soooo...
By extension, if the 02-05 and 06+ Power Commander III are physically and electronically compatible, then the new Power Commander V for the '09 VFR800 should work on ALL previous VTEC bikes, right?
Power Commander V for 2009 VFR800
Right?
Because that would be AWESOME!
Lacy
[image: View Post]VFR800R, on Apr 13 2009, 10:28 PM, said:
Soooo...
Right?
Lacy
I don't see why not.
Soooo...
Right?
Lacy
Wait, what is the difference or advantage between the PCIII and PC V?
Soooo...
Right?
Lacy
I know for a fact that speedohealers don't interchange for all VTEC's as honda changed the speedo sensor connector (why? dunno') through the years. I would suspect that a major connector like the ecu would NOT change but......
Sorry for adding some noise to the signal.
