Trackday + Centerstand Removal
6 posts Started 23 Apr 2009 Last recovered post 23 Apr 2009 Wayback Machine snapshot 12 Apr 2010
Hello All,
I am trying to remove my centerstand before a trackday this weekend. The right bolt has a serious clearance issue with the header pipe in the way. In addition, I heard something about this bolt being a reverse thread. Is that true? Any tips on easy removal would be much appreciated. I really don't wanna pull the exhaust to do this. Thanks a lot.
-Ryan
I had to loosen/ remove the header to remove the bolt. Dont remember it being reverse threaded.
I don't think the 6th gen is much different in that area than the 5th gen. I was able to flex the header pipe enough to get the bolt out. It was a tight squeeze but it did come out. Once I got it out I shortened the bolt enough to get it in and out easily. The bolt is more than long enough to hold things when shortened.
I had no problem leaving the centerstand on for track days on my 5th Gen.
The only thing that dragged was the header pipe. :blink:
Raising the rear a bit fixed that.
Raising the rear a bit fixed that. :+1: Noticed some of the guys ziptied their passenger pegs, side stand etc. Removal is a bit of a pain. Good luck.
WARNING WILL ROBINSON!!!!!!!!!!!!!!!!! DANGER ! DANGER !
The right side center stand bolt is indeed a left handed threaded bolt. Look at the little arrow on top of the bolt.
Ask myself and Jeremy how we know this for a fact.
End of thread · 6 posts recovered Wayback Machine snapshot 12 Apr 2010
