Power Commander Map Needed
5 posts Started 23 Apr 2009 Last recovered post 25 Apr 2009 Wayback Machine snapshot 12 Apr 2010
I have a 06 vfr with LeoVince SBK OVAL EVOII ALUMINUM exhuast and im getting a PC3 and 02 eliminators tomorrow . Was wondering if anyone has a custom map that works well with the Leo's, that they could send me.
Just run Coyze's map, should work great for you, you can find it in the downloads section of this site. (VFRD menu at the top, then click VFRD Downloads).
No, won't work on the '06. You'll have to change some settings. Because the VTEC engages at a different RPM. Other than that, It will work. I use the Stock map from PC & tweaked it a little. PM me and I'll send it to you. Although I have the 2Bros, not LeoVince....
2 bro's vs. leo vince will make very little difference. They will both flow better than your cat.
you can use my map, it was made by Velocity dyno in San Antonio. They did a good job, it should be in the downloads section.
End of thread · 5 posts recovered Wayback Machine snapshot 12 Apr 2010
