Air Cleaner Question
4 posts Started 8 May 2009 Last recovered post 8 May 2009 Wayback Machine snapshot 12 Apr 2010
Is there somewhere on this forum that explains how to perform simple procedures such as accessing and changing the air cleaner, adjusting the chain, etc?
http://www.vfrdiscus...p...&showfile=9
Here is the service manual. All the info you need for that in one place!
Air cleaner is easy. Loosen the two bolts on the front of the fuel tank. Hold the tank up with something, and unscrew the screws holding the top of the air cleaner down.
To adjust the chain, you'll need the tool supplied with your bike. Super easy to do because of the SSSA. :)
One quick tip on removing and reinstalling your air filter: Magnetize the end of your screwdriver, or have a magnetized extandable wand handy when you're removing the screws. There are a couple tight spots where those screws go in. Dropping one and having to dig it back out would be tough.
+1. Having one of those magnet on a stick thingies and a magnetized screwdriver does help.
End of thread · 4 posts recovered Wayback Machine snapshot 12 Apr 2010
