I know I could look this up somewhere, but I'm already on the road and can only check from my phone, and would like to add some preload. Do I turn the adjustment wrench up or down to add preload?
Which Way Do I Turn To Add More Preload To The Rear?
3 posts Started 14 May 2009 Last recovered post 14 May 2009 Wayback Machine snapshot 12 Apr 2010
[image: View Post]Ryanme17, on May 14 2009, 07:09 AM, said:
I know I could look this up somewhere, but I'm already on the road and can only check from my phone, and would like to add some preload. Do I turn the adjustment wrench up or down to add preload?I believe you have a stock shock, and if that is the case you can see the ramps as you turn the collar. And FWIW, you will be turning the wrench towards the front or rear of the bike, not really up and down.
I know I could look this up somewhere, but I'm already on the road and can only check from my phone, and would like to add some preload. Do I turn the adjustment wrench up or down to add preload?From the manual for a non-abs:
Turn clockwise:
Decrease the spring pre-load
Turn counter-clockwise:
Increase the spring pre-load
Pre-load adjuster standard position:
2nd groove
End of thread · 3 posts recovered Wayback Machine snapshot 12 Apr 2010
