[image: View Post]spud786, on May 31 2009, 08:33 PM, said:
[image: View Post]johnmark101, on May 31 2009, 06:16 PM, said:
Most likely the CCT. If it is the CCT, it's no problem to continue to ride it. It's more of a nuisance than anything, but should eventually be replaced.
Mine is rattling a bit on the right side at 30,000 miles. May wait until the second valve clearance check to replace it.
Replacing its a crap shoot, that you dont end up with the same issue only a couple thousand later, like me. Hell of a lot of work for nothing.
I got alot of flak, when I mentioned simple 10w40 EXXON superflow car oil fixed my issue over 25,000 miles ago. I did go back to another oil for test purposes and the tentioner noise came at about 1000 mile later. After that it was clear
10w40 exxon superflow, not a peep on the front cct running it
The front tentioner, is near vertical on the vfr, its hard for oil to get up in there, there are also some other oils, people say they've had no cct noise.
Give it a shot before shelling out $200 on a temporary fix, that will come back
I have 60,000 mile on my 06
Now what I'm reading is that the CCT makes noise at idle not under load. But his doesn't make any noise at all until past 5,000 rpms. Does that still sound like the CCT. I'll tell him about the oil it's worth a try anyway. I know he's been running 10w40 honda oil since it was new
