Venture Shield... Any Good?
2 posts Started 6 Jun 2009 Last recovered post 7 Jun 2009 Wayback Machine snapshot 12 Apr 2010
I am having the bike resprayed and i want to keep it as new as long as possible ;p
Is anybody using Venture Shield? Would it cover the whole bike?
I am particulary interested to know if the tail is covered. It seems that i cannot lift my boots enough and always end up kicking the tail section when getting off. :rolleyes:
Maybe I should remove the spurs :laugh:
I've used it on my bike - you can't get a custom template for the bike, but I got a medium sized rectangle, and covered the pillion cover, and the sides and tops of the tank, and the small bulges at the bottom of the fairings, that are the only bit of the fairing to contact the grounds if you lay it on it's side (as I found out)....
it's good stuff, but there is a bit of a learning curve to putting it on cleanly - use lots and lots of the fluid...
End of thread · 2 posts recovered Wayback Machine snapshot 12 Apr 2010
