Is A Cbr Mirror Close To A Vfr Mirror?
4 posts Started 24 Jun 2009 Last recovered post 24 Jun 2009 Wayback Machine snapshot 10 Apr 2010
I was at the dealership the other day and took a quick look at the new CBRs. The mirrors looked pretty similar to VFRs. I was in a rush and didn't have time to ask the part people, but does anyone have any experience with this? I'm looking for a cheap temporary replacement until I get the other set installed with integrated lights and the CBR mirrors seem a lot more common on fleabay.
Just wondering.
ppm
Bolt pattern is the same at least from 2000-2006 across the board on Honda sporting bikes. Mounts are near identical, save for angle. The stalks are shorter on the CBR mirrors, combined with the different angle will still serve as a rear mirror, but how much of the road you will see is questionable...
Edit: just get a cheap set of knockoff VFR mirrors. They're only about $18 each IIRC, from Emgo. www.denniskirk.com carries them.
Hey Seb,
Now, that is a great idea to get the knock off. It'll be perfect as a temporary fix.
Thanks Seb!
C
I had a set of the emgo cbr mirrors on my 04 at one point. The angle of them coming off the front is a lot lower. Low enough, in fact that you have a more clear and unobstructed view behind you. IIRC I had to take the right mirror and put it on the left and vice versa to get the angles to work correctly...
End of thread · 4 posts recovered Wayback Machine snapshot 10 Apr 2010
